SOLD! Channel Islands Audio D500 MKII
0 Members and 1 Guest are viewing this topic. Read 1485 times.
spab
« on: 13 Aug 2017, 11:39 pm »
SOLD!
Channel Islands Audio D500 MKII Class D Monoblock Amplifiers
500 watts into 8 ohms
800 watts into 4 ohms
Amps are in excellent shape (no real blemishes). Work flawlessly. They have the older style face plate (see pics).
2nd owner
Current Retail $6000
Sell $2500 shipping included in ContUSA
Have OBM
Located in 63141
« Last Edit: 18 Sep 2017, 07:54 pm by spab »
spab
Re: Channel Islands Audio D500 MKII
« Reply #1 on: 30 Aug 2017, 01:54 pm »
Bump
with lower price.
actimation
« Reply #2 on: 3 Sep 2017, 05:55 pm »
Hi there!
What is the gain for this pair of D500s?  Is 38 db or 32 db?
Much thanks!
best,
mark
spab
« Reply #3 on: 4 Sep 2017, 02:04 am »
According to the instruction manual:
Gain:  38db (for use with VPC, PLC or other passive preamplifiers)
        or 32db (for use with active preamplifiers)
So, rather than the amps being produced with two separate possible gains for all applications, the amps provide 32 or 38 db of gain depending on whether you are using an active or passive preamplifier.
actimation
« Reply #4 on: 4 Sep 2017, 02:09 am »
Thanks for the reply!
If that is the case, is there a switch for changing the gain?
The current iterations of the amps are fixed at a particular gain and I thought previous iterations were the same as well.
spab
« Reply #5 on: 4 Sep 2017, 03:15 am »
The specifications in the owners manual on the website for the amps are exactly the same in my owners manual:
Specifications
Power Output: 500 watts @ 8 ohms/800 watts @ 4 ohms
Bandwidth: 50kHz
Frequency Response: 10Hz - 20kHz, +0dB/-0.5dB
Damping Factor: >1000
Input Impedance: 100k ohms
Dimensions:8.5"w x 4.0"h x 13.5"d
Weight: 28 lbs (each)
So, I believe the amps are exactly the same -- the back is identical as on the website - no switch for gain, only a switch for balanced or single ended. You would have to ask Dusty why the gain differs depending on whether you have an active or passive preamp connected to them.
