Tidal and the Pi
0 Members and 1 Guest are viewing this topic. Read 1088 times.
schmidtmike76
Tidal and the Pi
« on: 12 Aug 2017, 09:16 pm »
Is there anyway to listen to tidal from the app itself on your iPad rather through applications on the bryston dashboard.  I have nothing but issues trying to get tidal to play.  Thanks Mike
bluemeanies
Re: Tidal and the Pi
« Reply #1 on: 12 Aug 2017, 09:22 pm »
I don't know if this will help as I am not familiar with the Bryson.
I am using APPLE TV to stream TIDAL from my iPad using the TIDAL app.
Use can also use APPLE AIRPLAY.
Hope this helps
schmidtmike76
« Reply #2 on: 12 Aug 2017, 09:30 pm »
I will have to try that.  I have 2nd gen Apple TV sitting there doing nothing anyhow
schmidtmike76
« Reply #3 on: 12 Aug 2017, 10:53 pm »
Is anyone else having issues with tidal right now via bryston
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 12 Aug 2017, 11:34 pm »
Hi Mike
I have the Pi as well as the BDP-3 and no issues with Tidal on either setup.
It is a streaming service so the network plays a large roll in the performance of Tidal.
james
schmidtmike76
« Reply #5 on: 13 Aug 2017, 12:27 am »
Sorry James it looks like my Pi has bit the bullet.  I can get the red light to come on but that's it the screen won't come on either.  The link on my phone won't detect the Pi either.  I'll have to call Monday
