Speaker Placement.
0 Members and 1 Guest are viewing this topic. Read 3173 times.
SundayNiagara
Speaker Placement.
« on: 7 Aug 2017, 01:52 pm »
Those of you who spent thousands of dollars on equipment, (especially cables) need to read this:
From Paul McGowan.
Taming your room
If you’re fortunate enough to have a room with workable dimensions as described in this post, you’re already ahead of the game when it comes to good sound. Proper room dimensions enable the rule of thirds to work well (which is how we manage to get such good sound in our room).
I am assuming you followed the advice for live/dead in this post, and are now ready to place your speakers and equipment.
Do as little as required. We often figure if a little room treatment’s good, more is better. And, that’s simply not true. In fact, often the opposite is what happens. I can’t tell you the number of rooms I have improved by simply removing a lot of unnecessary clap trap.
Start with an empty room. To the best of your abilities (being respectful of your spouse) clear the room of anything unnecessary. Place the speakers and listening chair—using the rule of thirds if you’re able—where you’d like them and make big adjustments to rough in the sound.
Add back in what’s needed for decor and livability one at a time. Make note of the sonic changes with each addition. Adjust as necessary.
After all three primary rules have been completed, now it’s time to add the finishing touches.
Diffusion is better than absorption. It is almost always s better to diffuse sound than it is to absorb it. When you diffuse sound waves you scatter their reflections so the ear can’t localize them. When you attempt to absorb them, you capture some and leave the others, forming a type of filter that skews tonality.
If you absorb sound, keep it to the corners and rear wall. Some absorption is ok if you use it for specific frequencies like bass, which builds up in corners and the rear wall. If you’re going to have any area of your room acoustically deader than the other, it is the rear of the room (behind the listening position) that will benefit.
Speaker and seating placement are more effective than room treatment. In general, this is true. If you have a decent room without any treatment, moving speakers and listening position to best advantage often gets the best results.
Pull the speakers out from the front wall. Few speakers on the planet benefit from being close to the wall behind them. Pull them out into the room.
Use the last three posts as a type of guide to help your system bring life to music.
"Rule of Thirds is quoted here."
Wind Chaser
Re: Speaker Placement.
« Reply #1 on: 7 Aug 2017, 02:35 pm »
Some of this I agree with, some of it I disagree, and some of it I don't know. Experience is the best teacher.
SundayNiagara
« Reply #2 on: 7 Aug 2017, 03:58 pm »
Start here:
"Pull the speakers out from the front wall. Few speakers on the planet benefit from being close to the wall behind them. Pull them out into the room."
Rule of Thirds?
lenkevy
« Reply #3 on: 7 Aug 2017, 08:13 pm »
From an article dated September 6, 2011 by Paul McGowan
Using the rule of thirds is simple: place your loudspeakers one third the total distance of the room from the rear wall and your listening position the same one third away from the opposite wall. For example, let’s say you have a room that’s 15 feet long and 12 feet wide. The loudspeakers would be placed 5 feet from the rear wall and your couch would be 5 feet out from the opposite wall. That’s it.
SundayNiagara
« Reply #4 on: 7 Aug 2017, 08:25 pm »
Amen! :)
Early B.
« Reply #5 on: 7 Aug 2017, 09:02 pm »
Nah. On the long wall, that puts you 5 feet from your speakers. Not practical and the sound won't be optimal.
es347
  • ..I've got my eye on you...which one you say?
« Reply #6 on: 7 Aug 2017, 09:57 pm »
..5 ft from the front wall
rich58b
« Reply #7 on: 8 Aug 2017, 01:49 pm »
I agree with Early B. In a room that is 15' long, and you place your speakers 5 feet out from the front wall, and your listening position is 5 feet out from the back wall, that puts you 5 feet away from your speakers. How can that be correct? I understood the rule of 3rds to mean that if your speakers are 8' apart, your seating position should be 8' from each speaker, thus forming a triangle with 3 - 8' sides.
SundayNiagara
« Reply #8 on: 8 Aug 2017, 10:19 pm »
Where did this come from? I never sat that far out from the wall behind me. Rule of thirds mean the speakers are out 1/3 from the wall behind them. NOT the seating position.
SundayNiagara
« Reply #9 on: 8 Aug 2017, 10:20 pm »
How long is your room?
es347
« Reply #10 on: 9 Aug 2017, 03:15 pm »
..the poster said place speakers from the BACK wall...just a typo I'm thinking
