Hooking up external HD's - I don't get something
0 Members and 1 Guest are viewing this topic. Read 1068 times.
charmerci
I hook up an ex HD and the Windows 10 software makes it drive E: - usually. I plugged something else in first so it registered that SD card as E: so when replugging in the HD, it registered that as F:
So now without anything else plugged in - and rebooted - it only registers the HD as F: - how do I get the computer to see it as E:?
The reason is - is because my JRiver playlists are marked under drive E:
Frustrating!
(SRB - are you there?  :lol:  )
srb
Re: Hooking up external HD's - I don't get something
« Reply #1 on: 3 Aug 2017, 04:29 pm »
I'm here!
Go to Disk Management
   Control Panel > Administrative Tools > Computer Management > Disk Management
   or just click Start button, type disk m and select Create and format hard disk partitions
Right-click on the drive and select Change Drive Letter and Paths
charmerci
« Reply #2 on: 3 Aug 2017, 04:49 pm »
Ha!
Great! Thanks a bunch!  :thumb:
