18" Tekton Sub ( used 6 months)
0 Members and 1 Guest are viewing this topic. Read 1671 times.
Delta77
« on: 1 Aug 2017, 02:35 pm »
You can see the oven & dishwasher in the background for size comparison
I have a nice 18" Tekton sub ($1,000 Retail)
It comes with a grill/cover ($75 Retail) ( some people have had trouble getting their grills ) Eric has a tough time keeping up with the grills
I can't fit two in my listening area (WAF).
I am going to get two woofers for my system.
I love this woofer it blends very well, and if you turn it up "wow"!!!
I don't know what to ask for ($) so I will ask the interested parties just send me a PM or call 559-647-4029.
I'm in Fresno Ca.
Also have Shiit Gungnir DAC for sale...
Both products are around 6 months old...
« Last Edit: 1 Aug 2017, 10:48 pm by Delta77 »
thunderbrick
  • I'm just not right!
Re: 18" Tekton Sub ( used 6 months)
« Reply #1 on: 1 Aug 2017, 04:36 pm »
Is it passive or active?
Delta77
« Reply #2 on: 1 Aug 2017, 06:14 pm »
Active 300 watt Bash.       (120 lbs)(massive)
"Proprietary design and concept
18" Subwoofer
Dimensions 33"(838.2cm) Tall x 20"(508cm) Wide x 26"(660.4cm)
100dB sensitivity 2.83V@1m
Frequency Response 19Hz - 200Hz
Weight 120 lbs
Manufactured in the USA"
I know 300 watts ?
 Believe me it's enough to drive this woofer. Claimed (100 db) efficiency.
It will shake your listening chair if you want it to.
   But to tell the truth I don't turn it past 1/3 up. (Loud Enough)
Most of the time I use it at the lowest possible audible level (1/8 up), just for the lowest bass notes.
I have never turned it up past 2/3 up, NEVER !!!
Not sure about other brands , but it blends VERY WELL with my SEAS PENDRAGONS !!!
This was a MAJOR step up from the  (15")  "Definitive Technologies"  sub I was using.   Both in Sound Quality & Output.
I told ERIC of Tekton The main objective for me when I bought it was :
  (1) it must blend better than my previous sub.
  (2) No funky "thud" noises, Real bass frequencies.
I would have sent it back if I didn't like it ,(believe me).   It does what he said it would.  I do like it.   " IMO" It blends way better & sounds a lot more realistic .
The only reason I'm selling is to get a pair of TEKTON subs that will fit the room better (WAF). 2 of these subs just won't fit, or I would not loose the money I spent on this one.
The Wife (Boss ) will not allow 2 of these in the living rm.
I will be happy to demo the sub as it is in my current system.
« Last Edit: 1 Aug 2017, 10:47 pm by Delta77 »
