Small Signal Model of a Triode Tube
0 Members and 1 Guest are viewing this topic. Read 1705 times.
bob82274
« on: 11 Dec 2004, 04:37 am »
This is a question for my fellow EEs.  Are there any good websites that have small signal models of tubes?  Equations are expected.  I have spoke with several professors about this however they are more focused on how to make their CMOS transistors smaller :roll:.  Are there any pieces of literature that are worth looking at?
I have taken a quick glance at several circuits involving tubes and understand their basic nature as a triode in relation to a BJT or a FET but I would like a more in depth look the device physics.
Thanks :mrgreen:
Occam
bob82274
« Reply #2 on: 11 Dec 2004, 05:41 am »
That stuff from Michigan is great! Thanks!  It looks like it will be at least a decent intro paper to read.
My favorite quote: 'Clearly the analysis is trivial once it is understood.'
Only in academia. :roll:
Do you know of any papers that have the theoretical definitions of Rp and Gm instead of the measured/data-sheet values?
I may look into the references cited from the paper for more info as well.
Again very good stuff! :D
Here are some
« Reply #3 on: 11 Dec 2004, 06:04 am »
u = gm x rp
gm = u/rp
rp = u/gm
Gm = change in plate current/ change in grid to cathode voltage with constant plate to cathode voltage.
Plate resistance = change in plate to cathode voltage/ change in plate current with constant grid to cathode voltage.
u = change in plate to cathode voltage/ change in grid to cathode voltage with constant plate current.
