Hi Everyone
0 Members and 1 Guest are viewing this topic. Read 1464 times.
BHD
Hi Everyone
« on: 27 Jul 2017, 06:44 pm »
Long time lurker, finally decided to join.
I'm a single driver speaker/SE amp/vinyl kinda guy, currently running Sachiko double horns with Fostex FE206ES-R drivers, Korneff 45 amp and assorted digital and turntable bits and bobs that get rotated in from time to time.  I'm currently looking into putting together an Oris horn system.  My wife and I have been buying tons of vinyl lately and I'm very lucky that she not only tolerates but encourages my madness.
What finally put me over the edge to join was the fact that I'm interested in buying an item for sale in the marketplace.  I know that's lame but I do plan on sticking around and contributing (if I can).
Re: Hi Everyone
« Reply #1 on: 27 Jul 2017, 08:15 pm »
Welcome  BHD :thumb:
Iam a FR fan, mainly Alnico.
I will PM you after 2 posts.
Phil A
Re: Hi Everyone
« Reply #2 on: 27 Jul 2017, 08:24 pm »
Welcome to AC!
BHD
Re: Hi Everyone
« Reply #3 on: 27 Jul 2017, 08:59 pm »
Hi Full range man.  I know you from DIY Audio, I've been a member there for years using the same moniker (BHD) good to see you here.
Thanks for the welcome, Phil A.   :D
Re: Hi Everyone
« Reply #4 on: 27 Jul 2017, 09:28 pm »
Thankyou BHD, good have you here;
I will PM you about your amp.
Regards
BHD
Re: Hi Everyone
« Reply #5 on: 27 Jul 2017, 09:55 pm »
Fullrangeman, I got your PM but it doesn't let me reply (probably because I'm new).
To answer your PM, I got the amp used, it's the integrated amp version and it's fantastic.  Jeff Korneff takes breaks from building amps from time to time so I don't know if he's still currently making them or not.  There are a lot of people out there claiming to build the "Korneff" circuit even though some of them aren't using the same tubes types of the original so be careful.  The only folks that I know of that have back engineered Jeff's amp circuit is Tube Audio Lab.  I'm not sure if he has Jeff's permission to use his circuit or not.  I can try to track down Jeff's  contact information for you, I know I've seen his email listed elsewhere.
By the way, can you or someone let member "Regalma" know that I'm interested in his Soundsmith SMMC-1 cartridge listed in the trading post?  I don't know how long it will be before I'll be allowed to contact other members directly (again, probably because I'm new).
http://www.audiocircle.com/index.php?topic=151769.0
Re: Hi Everyone
« Reply #6 on: 27 Jul 2017, 10:19 pm »
OK Thanks. I will inform Regalma for you.
I know Tube |Audio Lab, he have patience and is friendly?
Re: Hi Everyone
« Reply #7 on: 27 Jul 2017, 11:09 pm »
Greetings & Welcome to AC BHD   :thumb:
BHD
Re: Hi Everyone
« Reply #8 on: 28 Jul 2017, 01:20 am »
Thanks Dent Arthur Dent.   :D
BHD
Re: Hi Everyone
« Reply #9 on: 28 Jul 2017, 02:17 pm »
FRM,
I don't know the owner of Tube Audio Lab but on his site he has done a rebuild of an actual Korneff 45 amp so he at least knows the real circuit.  I've seen some amps put up for sale as "Korneff" amps that don't even use the correct tubes so you need to be careful.  Real ones come up for sale every so often so keep your eyes open.  I got very lucky and came across the integrated version that combines his 76 preamp with the 45 amp in one chassis.
It is a fantastic amp if your speakers are efficient enough.
Re: Hi Everyone
« Reply #10 on: 28 Jul 2017, 04:49 pm »
My FR is not efficient enough(94dB) but I plan use other output tube and circuit.
