Bookshelf Speakers (Klipsch, AV123)
0 Members and 1 Guest are viewing this topic. Read 1788 times.
aboroth00
« on: 26 Jul 2017, 11:01 pm »
I have a couple pairs of bookshelf speakers that are just sitting around unused.  They're all fully functional and for the most part in good condition.  Some of the speakers have some cosmetic imperfections but nothing that compromises performance.  Drivers are in tip-top shape.
I used these for fun inexpensive desktop setup and swapped out speakers here and there.  I always admired Klipsch as very efficient speakers with little need for expensive amps.  The AV123 speakers are quality speakers which have some heft and size.  They have some scratches on top from a vase unfortunately but otherwise in pretty good condition.
Local pick up in Socal only.  More than welcome to come by and check them out.
AV123 X-CS Pair in Black - 100$/pr
System: Two way, three driver directradiating system, sealed enclosure
Drivers: 1″ treated fabric dome and two custom 6.5″ curvilinear shaped treated paper cone woofers with polymer chassis
Crossover: 2100Hz, 2nd order Frequency Response: 65 Hz to 20 KHz (± 3 dB) Impedance: 8 Ohms nominal
Efficiency: 90.5 dB (@ 1 watt / 1 meter)
Dimensions: Horizontally Oriented: 8.5″ H x 20.0″ W x 15.5″ D; Vertically
Oriented: 20.0″ H x 8.5″ W x 15.5″ D
Weight: 33lbs each; ship weight = 41 lbs
Klipsch R-14M - 80$/pr
FREQUENCY RESPONSE
64Hz - 24kHz +/- 3dB
SENSITIVITY
90dB @ 2.83V / 1m
POWER HANDLING (CONT/PEAK)
50W/200W
NOMINAL IMPEDANCE
8 Ohms Compatible
LOW FREQUENCY EXTENSION
58Hz
CROSSOVER FREQUENCY
2250Hz
HIGH FREQUENCY DRIVER
1" (2.54cm) Aluminum diaphragm compression driver
mated to 90° x 90° square Tractrix Horn
LOW FREQUENCY DRIVER
4" (10.2cm) copper spun magnetically shielded
IMG woofer
ENCLOSURE MATERIAL
MDF
ENCLOSURE TYPE
Bass-reflex via rear-firing port
INPUTS
Single binding posts
HEIGHT
9.75" (24.8 cm)
WIDTH
5.88" (14.9 cm)
DEPTH
7.5" (19.1 cm)
WEIGHT
7.13 lbs (3.2 kg)
FINISH
Brushed Black Polymer Veneer
BUILT FROM
2014
Klipsch RB-15 - 100$/pr
Description: Two-way, reflex-loaded, magnetically shielded, stand-mounted loudspeaker. Drive-units: 1" (25mm), titanium-dome compression-drive tweeter with 5"-square, 90 degrees by 60 degrees Tractrix horn; 5.25" (133mm), hard-anodized aluminum-cone woofer. Crossover frequency: 2.84kHz. Frequency response: 70Hz-20kHz, ±3dB. Sensitivity: 93dB/2.83V/m. Nominal impedance: 8 ohms. Power handling: 75W (300W peak).
Dimensions: 11.2" (285mm) H by 6.5" (165mm) W by 7.75" (197mm) D. Weight: 9 lbs (4.1kg) each.
Finishes: Black Ash or Light Cherry woodgrain vinyl.
Serial numbers of units reviewed: CH-03120653, CH-03130653.
Price: $299/pair.
Read more at https://www.stereophile.com/content/klipsch-rb-15-loudspeaker-specifications#CIVsh2LXgTXdf6UX.99
Sparky14
Re: Bookshelf Speakers (Klipsch, AV123)
« Reply #1 on: 28 Jul 2017, 03:34 pm »
Where in SoCal?
aboroth00
« Reply #2 on: 3 Aug 2017, 02:01 pm »
Where in SoCal?
The speakers are in Garden Grove, but I travel to LA and SD now and then.
