Coincident Statement Phono Preamplifier
0 Members and 1 Guest are viewing this topic. Read 1447 times.
sonorlite
« on: 24 Jul 2017, 04:30 pm »
Excellent condition Coincident Statement phono preamplifier. Original owner, kept in smoke-free room.
Asking $3800.
Buyer pays shipping and PayPal fees.
Specifications:
Frequency Response: 10hz – 25khz +/- .1 db
Gain: 66 db- MC
Output Impedance: 250 ohms
Maximum Voltage Output: 30 V
Impedance: 3-10, 11-30, 31-100, 101-300 – MC
Phase: In phase
Dimensions: 10.25 W x 14 D x 8 H – Power Supply and Phono
Weight- Power Supply – 18.5 kilos (40.4 lbs)
Phono Stage – 9.5 kilos (20.9 lbs)
AC Voltage: User Selectable – 115V or 230V
Tubes- 4-12AX7- Reissued Mullards are included.
User Features:
Finest Discrete Resistor Dual Mono Volume Pots - Allows for Direct Connection to Amplifier without the Use of a Line Stage and corrects for channel imbalances;
Dual Pairs of RCA Outputs- Allows for Biamping;
Impedance Selector-Optimizes all moving coil cartridges;
Mute Switch – Conveniently mutes signal when changing records;
AC Voltage Selector- Permits user to switch voltage for operation worldwide;
Lift AC Ground - Conveniently breaks AC ground to eliminate hum caused by ground loops. Line Input is now standard.
« Last Edit: 6 Aug 2017, 04:00 pm by sonorlite »
sonorlite
Re: Coincident Statement Phono Preamplifier
« Reply #1 on: 10 Aug 2017, 12:42 pm »
Price drop to $3,500.00
« Last Edit: 11 Aug 2017, 07:20 pm by sonorlite »
sonorlite
« Reply #2 on: 17 Aug 2017, 06:55 pm »
Bump
