Can I Use Two Different Subs in the Same System?
0 Members and 1 Guest are viewing this topic. Read 1648 times.
witchdoctor
« on: 22 Jul 2017, 03:48 pm »
I am changing offices to a bigger room and I am thinking of adding a second sub. My office system is used 90% for music. I have a pair of JBL 230 speakers and a TBI Magellan subwoofer. TBI subs are known for seemlessly blending into a room, not as home theater room rumblers.
http://www.stereotimes.com/speak112204.shtml
I am thinking of adding a second sub. I want to try a JBL sub as I have JBL speakers but am worrying that two subs of different types/brands won't harmonize. Any opinions?
artur9
Re: Can I Use Two Different Subs in the Same System?
« Reply #1 on: 22 Jul 2017, 09:28 pm »
I have a pair of TBI that I use.  They are great subs for music but don't like LFE much, as you say.
Now, I have a complicated setup with some other subs to go lower/louder for movies and to smooth the bass.  3 different subs: an Outlaw Audio M8, an SVS SB1000 and then the TBI.  There's no denying that using identical subs would have been easier.
I could integrate them well because I have a measurement mic and software (room eq wizard, aka REW) and an external DSP.  I followed the Geddes method described here https://mehlau.net/audio/multisub_geddes/.
It takes a long time but is well worth the effort.
twitch54
« Reply #2 on: 23 Jul 2017, 01:00 am »
how big is the room ?
witchdoctor
« Reply #3 on: 30 Jul 2017, 02:19 am »
thanks, i think i will get a matchibg tbi, this system is just for music and keeping it simple is good
witchdoctor
« Reply #4 on: 30 Jul 2017, 02:21 am »
typical bedroom size, maybe 10' by 11'
« Reply #5 on: 30 Jul 2017, 11:34 am »
Do you really "need" two subs in a 10ft x 11ft (small) room?  (Except to try getting rid of the bass peaks/dips inherent to a nearly square room.)
witchdoctor
« Reply #6 on: 30 Jul 2017, 01:44 pm »
Good question, no I suppose not. I saw a great deal on a JBL sub that matches my speakers which raised the question and I have been known to purchase gear I "want" but really don"t "need". I'll bet that has happened to most members. A thread like this sometimes slows down that impulse buy which is a good thing, thanks. :D
