Paul Hynes VCF Phono Stage
0 Members and 1 Guest are viewing this topic. Read 845 times.
rtm00x
« on: 21 Jul 2017, 10:11 pm »
Want to see if there is any interest in this phono stage. I bought here a few years ago for $800. I found it had some mechanical noise when it arrived, long story short, worked with a friend to cut the top of the power supply case off and replace with wood to take care of that issue. It's better than how it was new :D. It wasn't my first option, but considering this was a design issue, and we verified that by taking the power supply out the case, it was the most practical in every sense. Came out looking pretty clean in the end, and dare I say even added a bit of class to it.
Sounds great, has a fairly decent set of tubes in it. The nice thing about it is it takes one 6DJ8 tube and one 12AT7, who doesn't like buying single tubes?? Selling it for $675, $650. Which, I personally, think is a steal. But I might be biased  :thumb:!
If you prefer to read the long story about the mod you can go here - http://www.audiocircle.com/index.php?topic=130129.msg1375612#msg1375612
« Last Edit: 25 Jul 2017, 01:14 pm by rtm00x »
rtm00x
Re: Paul Hynes VCF Phono Stage
« Reply #1 on: 25 Jul 2017, 01:14 pm »
Price drop to $650
