0 Members and 1 Guest are viewing this topic. Read 5745 times.
The Sonographe is a really nice table that was well reviewed in its time, the ES1 has much better specs. For example .1% vs .04% wow and flutter, respectively. Of course specs aren't everything and I don't know how they compare soundwise, but when I first read your post my initial though was lateral move. And with used condition is everything so the no name Japanese tonearm is a concern, could be great or horrible. I suppose I'd decide based on intended use, if adding to your stable I'd go for it, if replacing the Sonographe I'd have to think long and hard, and do more research.
I had the Hurst motor modded by Merrill years ago put it in my Sonograph sg3, I don't think it really hummed alot less than before but I think the tolerances inside got tightened up more and wobbled less. Perhaps its the same Gem Dandy mod but done by Merrill instead. Audio nirvana has a motor controller that might work but not sure if that's going to improve the sound.I don't think I can get any of these to a vpi scout jr level or can I? Check out the Soundofthewood website and see how far they went modified to the hilt with the Acoustic Research ES1 and that's why I asked ,is it that good?
