0 Members and 2 Guests are viewing this topic. Read 16361 times.
Not sure what your budget is, but Larsen speakers are actually designed to be placed against the wall. They come at three price points and in four finishes:http://www.larsenhifi.com/en/larsen6.htm
I don't let the hammer tell me what wood to buy
And pants. I especially don't takes his advice on pants either.
(Someone also please tell me why speakers with no drivers or even ports/passive radiators on the back are so sensitive to placement near walls? The sound is radiating from the front.
You might try these too. They're made to be placed near rear boundaries and designed by one of the (somewhat lesser known) legends from home audio's golden age. http://directacoustics.com/?page_id=16
ETA: My natural impulse is to 'defend' the Larsens even though I know next to nothing about them; much less how they sound, beyond others' descriptions. Simply because their creators took the time to address a real issue: many (dare I say most) people actually do push their speakers up against the wall.
My understanding is that although the drivers are in front the "wave launch" is still spherical in nature. Unless one is talking panel speakers like Magnepan, which are designed to "beam" to a certain extent to eliminate room interaction. AIUI etc. Line arrays like Carver's Amazing Linesource also have a different radiation pattern.
The sound is radiating from the front. I do have a rudimentary knowledge of physics and studied wave theory way back when.
Just my attempt at a sane real-world response to the OP's genuine interest in fitting a system into his nicely appointed real-world room.
You'll see when you get the HTDs and experiment a bit with placement.
I think noway sums up the realities of the situation: Beautiful room, but a tough go for sound unless some fairly significant changes are made.
You know, I've gotten some very pleasing living room sound with some old Wharfdale monitors/bookshelf speakers on actual bookshelves, powered by a basic modern $300 HT receiver from Best Buy - with a Dayton 12" sub in the corner. This has been my parents' setup for years since I set them up with it. And when I visit over holidays, and we play some kind of background music or a concert on TV/DVD, it fills the room, is articulate with good detail, has an attractive warmth to the midrange, and is generally engaging. I think that's all the OP is looking for, and I believe can totally be achieved in his room with modest investment relative to audiophile standards. No, the setup will not soundstage like the devil, and there may be some image smearing due to that cabinet. But it won't be the end of the world, and can result in a very satisfying sound as long as critical listening is not his passion (which he's clearly stated is not his thing). I say get some Clue speakers - which are small monitor-style speakers designed for relatively full bass response when placed directly against a wall. Put them on some nice solid stands that elevate the sound above that lounge. Hook up some of those tube amps, or get a decent SS integrated amp with tone controls. Definitely consider a subwoofer you can place over in that right hand corner out of the way and hidden by a plant or something. If not the Clue, then some Salks. Actually, some Salk Songtowers would probably look and sound great there. But as a jazz lover, I'd highly recommend calling Louis Chocos of Omega speakers - his single driver speakers are definitely meant for jazz lovers. And some of his designs are also meant for placement along a wall - I believe the Super 3XRS, but maybe others. He does really nice wood cabinet finishes. Regarding the rear ports - there's nothing to stop you from putting a rear ported speaker up against a wall. But yeah, you'll be attenuating the output from that port for sure. Which will be in the lower frequencies. So, again, highlights the importance of considering a subwoofer out of the way in your plans.I've mentioned all of the above with the caveat that the OP is willing to accept sonic compromises and not get the most out of his speaker investments. Yes, up against a wall will almost always compromise imaging/soundstaging, and depending on the design also will muck up low frequency overall responses. However, these compromises don't mean he won't have ANY imaging/soundstaging, and it doesn't mean he can't have a healthy bass response if other active measures are considered. Just my attempt at a sane real-world response to the OP's genuine interest in fitting a system into his nicely appointed real-world room.
A 60 Hz sound wave is 220 inches (over 18 feet) long so a spherical dispersion can be expected from any sized woofer.
Infinite baffle speakers/sub address that?
There should be nothing between the speakers. If you must, keep it low. The high reflective bookcase with vibrating glass is not good.Both speakers should see the same room characteristics. If one has a wall behind it and a wall beside it, so should the other.Do not have untreated sidewalls. Avoid sidewalls with windows. Do not have speaker firing across objects (sofa) on their way to the listening position.Do not automatically put speakers close to the front wall. They will usually sound best a ways out. It is a beautiful room but I wouldn't recommend investing any money into the audio equipment until the room issues can be worked out or a new room found.
OUCH !! I guess I am supposed to be offended by such a statement.Sorry to inform you I am not.I am very proud of what I have accomplished in driver design, and I am proud of how I have gotten there, by countless hours of building drivers and exploring alternative methods, and attempting to understand how and why they do what they do. And not just reading books written by others who say this is how it must be done and feeling satisfied when I reach the same conclusions they have reached. Too bad your not closer to Long Island NY...In the event you do come up this way or come to CAF 2017 be sure to look me up.I would be glad to give you a lesson in speaker designing by ear first and measurement second.But then again considering your stubbornness to accept something different, it would probably fall on deaf ears.Sleep well, I am sure your system measures perfectly !!Greg
Bottom lines:1.) There is no perfect loudspeaker.2.) The room and speaker/listening position setup have a much bigger effect on speaker performance than most would like to admit. 3.) Most audiophiles buy gear based at least in part on visual aspects and to be entertained versus to gain an accurate reproduction of what the recording professionals hear.
