0 Members and 1 Guest are viewing this topic. Read 6747 times.
Has anyone ever heard of these Chinese made Choseal Q940 banana plug set? They say they are high purity copper with gold plating and they look very simple and look pretty.Once I can find out where to get some from a good source I will get some to try out . It seems to offer a very reasonable low price too . Good for DIY speaker wiring up project to replace my old MIT terminator 4 bi-wire which tends to have a somewhat bloated sound to it.Also there is a cheaper Q906 without the sleeves too. google those on images
Most of the BFA / Z style plugs I have seen are made from beryllium copper alloys that are needed to provide spring tension (like the Multi-Contact LS4 that I use).The only plugs of that style I have seen that use a more conductive copper are the Furez banana plugs made from C14500 93% IACS Tellurium copper and use an elastomeric insert for tension. They are also available in a silver-plated version that has a 105% conductivity.They're not cheap, though, going for ~ $15/pair for the bare copper version and ~ $25/pair for the silver-plated version. (They don't seem to offer a gold-plated version). Steve
what are the diffrences betweeb the sizes?
Is this your source?http://www.douglasconnection.com/Furez-Products_c20.htm
Why do they have to put plastic inserts inside the copper tube section of the Furez. Does that mean the metal is thin and soft and would bend or twist easy? Perhap if they made the copper thicker,hmm?
The elastomer is there for vibration control from what I have read.
How can one have 105% conductivity? Seems to violate the laws of physics.
you have to ask yourself %105 of what? what is the baseline? ..... it is just conveniently vague. just marketing nonsense really .....
It's not vague or marketing nonsense. IACS (International Annealed Copper Standard) was developed to compare the electrical conductivity of copper.Using the conductivity of commercially available annealed copper (resistivity of 1.7241x10-8 ohm/meter at 20°C) as a baseline of 100%, it is also used to compare the conductivity of other metals and alloys to copper.https://www.bluesea.com/resources/108/Electrical_Conductivity_of_MaterialsSteve
