BDP3 power to BOT
0 Members and 1 Guest are viewing this topic. Read 660 times.
rmurray
BDP3 power to BOT
« on: 12 Jul 2017, 01:29 am »
Sorry  but can you help lift my confusion? :scratch:  Can the  BDP3 supply power to the BOT or does the Bot use a  "wall wart" supply? Thanks james
srb
Re: BDP3 power to BOT
« Reply #1 on: 12 Jul 2017, 02:01 am »
The BOT-1 requires a 12V/1.5A power supply; USB voltage is 5V.
The included external power supply connects to the BOT-1 with a 15-pin D-Sub connector.  The literature and manual mentions an optional matching higher performance BPS-3 multi-device power supply, but I don't think that product is available yet.
