0 Members and 1 Guest are viewing this topic. Read 2652 times.
Gun supplies.. Plenty of foam in ear 32+dB noise stoppers.. about 50 cents to $1 a pair.I bought a tub of 50 pairs.. each pair in a small sealed baggie.You squeeze them and the put them in. As they re-expand.. the World of noise drops away..The downside is moisture. if your ears sweat inside..You can add pro headphone like ear protectors for an additional (up to) 37dB...With both.. you ARE deaf. But your ears are protected totally...44 magnum goes off next to your ear? you will not hear it.(well, you might feel it..)
Having in ear and over ear provides more than enough protection
