X box one X analog audio out to Modwright Eyse DAC
0 Members and 1 Guest are viewing this topic. Read 1365 times.
stump4545
« on: 11 Jul 2017, 04:50 pm »
going to pick up a new X box one X when it comes out.
Want to hook it up to my HiFI 2 channel rig.
Only problem is my Elsye DAC only does not have an optical input. :cry:
Anyone have any ideas which would be the easiest high fidelity solution?
I have a DM 36.5 Modwright pre amp also not sure if that helps.
thanks a lot
jaywills
Re: X box one X analog audio out to Modwright Eyse DAC
« Reply #1 on: 11 Jul 2017, 05:09 pm »
I think that optical to s/pdif adapters are fairly easy to find.
https://www.monoprice.com/product?p_id=2948  (no affiliation)
I suspect that you can pay a premium for premium parts.  I use one of these with good results (again, no affiliation);
http://ifi-audio.com/portfolio-view/accessory-spdif-ipurifier/
Good luck.  Cordially,
stump4545
« Reply #2 on: 11 Jul 2017, 05:11 pm »
Will i lose a lot of fidelity by using those converters?
jaywills
« Reply #3 on: 11 Jul 2017, 06:36 pm »
I can't speak to the first one I listed, it was just an example.  As to the second one, one I actually own, it is sold in part to improve fidelity.  I have enjoyed having it in my system between my DAC and my s/pdif sources.  Of course, YMMV.  Cordially,
stump4545
« Reply #4 on: 12 Jul 2017, 12:10 am »
so that second one converts optical to digital coax?
can seem to find cost for it, also do I buy it from that site?
lastly any way I can plug my x box one x into my Oppo 205 4K player and have my oppo output analog stereo to my dac?
does that work?  hmmmm......
srb
« Reply #5 on: 12 Jul 2017, 12:26 am »
You keep mentioning outputting analog audio into your Elyse DAC.  The DAC only has digital inputs.
But yes, you can connect the Xbox One X into your Oppo player via Toslink optical and the Oppo analog output connected to your Modwright preamp.
stump4545
« Reply #6 on: 12 Jul 2017, 12:57 am »
Nice so my Oppo 205 can decode the digital audio and then output analog to my DM 36.5.
The Oppo will mix down to 2channel stereo.
This sounds good.
Thank you
