Sold Bob latino built dynaco st70
0 Members and 1 Guest are viewing this topic. Read 2307 times.
skite30
« on: 1 Jul 2017, 08:07 pm »
This was built by bob and includes the 12au7 upgrades and russian PIO caps.   In great condition.  Comes with gold lion kt-66's.  Individually biased and can use el34, kt77, kt88's.  Can use 6550's with a reesistor change.
Great sounding amp.  1,400 new.  Asking 700 plus shipping from 32080.
« Last Edit: 7 Jul 2017, 02:02 pm by skite30 »
WireNut
Re: Bob latino built dynaco st70
« Reply #1 on: 1 Jul 2017, 08:47 pm »
Very Nice  :drool:
restrav
« Reply #2 on: 1 Jul 2017, 08:51 pm »
what is the power output with the KT66?
REDBEAN
« Reply #3 on: 1 Jul 2017, 09:08 pm »
Is that a volume control knob on the front of the amp?
skite30
« Reply #4 on: 1 Jul 2017, 11:52 pm »
Poser output with the kt-66 is about 35 per channel in ultralinear mode and 20 in single ended. It can swith between the two modes on the fly with just a slight pop.  That is a volume control.  It is passive with 1 input so it can be used as an integrated. A very versatile and really good sounding amp.  For the money it is great value.
skite30
« Reply #5 on: 2 Jul 2017, 12:49 am »
Yes triode.  R two toggle switches in front of the transformers that allow u to switch between the two. I have the assembly manual. Bob increased the size of the original st70 transformers.  It uses 12au7 tunes instead of the 7199's.  i have Been using 12bh7a's in it.
E
skite30
« Reply #6 on: 2 Jul 2017, 12:51 am »
Sorry it is not a triode it is a pentode tube obviously, wired in single ended mode.
restrav
« Reply #7 on: 2 Jul 2017, 01:20 am »
do you have the tube cage?
skite30
« Reply #8 on: 2 Jul 2017, 04:12 am »
It never had a tube cage.  I guess one of the old st70 ones might fit.  This is not a rebuilt st70. It is an all new amp based on the st 70.   U can go to the tubes4hifi.com website to read all about this amp.
Bostown
  • BASS CLUB [Boston Audio Stereo & Social Club]
    • Second Time Sound - Audio Gear Re-Purposed
« Reply #9 on: 2 Jul 2017, 02:26 pm »
Yes, a Dynaco ST70 Cage will fit. I'm using on my Latino VTA ST70.
  hell, $1000- $900 is a deal.    $700 ? this should have been gone within seconds of being listed :)
Not sure why there needs to be any changes to use 6550's vs any of the other tubes mentioned.
skite30
« Reply #10 on: 2 Jul 2017, 05:38 pm »
When I put the 6550's in I was unable to bias them down in the operating range. Bob said it would probably a resistor change to get them to bias right. I didnt do it. I dnt know if running them a bit hot would damage the amp or just shorten tube life. So that leaves me with a matched quad of new issue tung sol 6550's if anyone is interested.
skite30
« Reply #11 on: 5 Jul 2017, 10:07 pm »
SOLD
Bostown
« Reply #12 on: 6 Jul 2017, 08:04 pm »
SOLD
I have a strong feeling that another one will be offered...
Friendly FYI.. change the first word in your Subject to SOLD!
