3 way custom Built Loudspeaker price Reduced $995- Worcester,Ma.
0 Members and 1 Guest are viewing this topic. Read 1652 times.
Audiophile58
  The cabinet - 1 inch thick front Baltic Birch ply - The Best A  grade,every other part same Baltic Birch  .I must make room  For my bigger model. - The price has Drastically been red
uced, Pickup only.  Come over for a listen .$4,000 invested only 6 months old. Pick up only Worcester,Ma.
Tel- 508-755-0870
Before passing any judgement ,without question you will not find anywhere
A loudspeaker at 2x the money that will be this well built or refined .Over 30 years
Of experience and research went into this. Take any $4k  commercially  built speaker for example
The cabinet or parts are built to a Low price point which I have documted below
These will last and are truly refined and built to last .Research the market
At $2000 you get made in China.  less then 25% of the build actually
Goes into any commercially build speakers. These speakers $4,000 and 50% or more went into the build .If you take the time to hear them you will buy them ,
In 3/4 inch thick, separation chamber for Bass 3/4 inch thick 2 cubic ft internal volume 3 inch rear
Precision port . Internally laterally internally reinforced,as well as around Woofer .all Bostic Acoustic
Glue used throughout on every seam internally as well as in between joints and nailed.
For damping all internal vibration resonances.  Upper Tweeter,Midrange 100% Natural Wool Felt used throughout,as well as back wall Acoustic damping rear wall. , for Bass cabinet 1/2 inch Acoustic
Open cell foam throughout.
Wiring  top cabinet Supra - Sweden,high purity Copper AWG- 15,  and for Bass - Supra  AWG 13        high purity Copper.
All Speakers - drivers are crimped with NO SOLDER , use only Furutech 24k plated  non magnetic Phosphor Bronze.
Which has effectively 6x more conductivity and much better sonic integrity then even the best solder.
The Crossover uses only Premium capacitors,inductors in all critical areas Hiigh frequency,Midrange .
German Mundorf- Supreme capacitors and Silver oil bypass caps for the Tweeter.
For the Midrange U.K - Clarity capacitor Best Copper C MR capacitors.  For midbass- Low Bass- French Aeon power capacitors. INDUCTORS , Copper open core  Jsntzen Denmark for Tweeter,Midrange. For midbass,lowbass Dayton - Solen Canada.
CROSSOVER connecting wire Neotech 5-9s pure Copper. Very minimal solder used to connect
Cardas,Best 4% Silver solder. The Loudspeaker terminals Cardas,Solid Copper for best possible
Conductivity.
The Loudspeaker drivers   for the Tweeter the Classic Morel - MDT-29 1.3inch soft dome cast frame Large Ferrite magnet fluid damped and cooled.
For the Midrange Dual - 4 inch  Vifa- Peerless wood pulp graphite composite cone  Mid driver with the latest Open architecture Cast baskets for most efficient cooling. .Neodymium Boron high flux magnets .
BASS is the 10 inch  Scan speak-  latest Classic series  Aluminum  anodyzed Cast basket  long throw
Woofer.  The Loudspeaker sensitivity is a Very efficient  90db at 1w, 4 ohms load 2nd order .crossover frequencies 200- Bass, 2500 Tweeter for  seamless driver transition.
All drivers we're  matched paired to 2% or better tolerences.   Linkwitz Riley crossover,capacitors also matched to within 2% .This speaker is  very easy to drive .Once the Loudspeaker was completed
Zebra wood laminate over the Baltic Birch for a Very inert cabinet. - to install. Over 40 hours went into this build.
This is a very High quality professionally designed Loudspeaker . Madisound Audio assisted in  the crossover design as well parts connection on driver- crossover parts. The Loudspeaker is still running in and is sounding Very refined and well balanced within its frequency band which is
30 hz to 25khz, AND WEIGH JUST OVER 70 LBS.This Loudspeaker is A precision  instrument. Please note the Majority of Loudspeakers
$10,000 or under use a far less expensive build process. mdf cabinet, Not thick Baltic Birch ply which is 3x
More expensive. One more thing,the reason most manufacturers do not speak of or display the heart of the Loudspeaker the Crossover is that they use very average parts at best.  there is Nothing made in China in this build.Did you know In all commercially built Loudspeakers 25% of the cost of the parts or less
Actually go into the build ,the rest overhead ,and 50% markup. In my Loudspeakers 70% goes Into the build of these Very labor intensive instruments. You will not find a better built Loudspeaker under $10k
That I can assure you ,  this is a Loudspeaker for the Audiophile who appreciates
Old world craftsmanship that will provide you many years of musical enjoyment ,Thank you .
« Last Edit: 3 Jul 2017, 11:34 am by Audiophile58 »
oskar
Those look like excellent speakers.
I bet someone is going to be very happy.
Carl V
the build looks nice.
it's the pick up only which will
slow things down
good luck.
Jolly
   If I had the room for those speakers I would grab them immediately! A VERY, VERY low price considering the quality of components used and very high build quality.
Audiophile58
Thanks Guys ,the sad part is these Very good Loudspeakers are getting past over for a name brand speaker 2x the cost
That is not 1/2 as good. This whole speaker was professionally built, Madisound Audio designed the 2nd order crossover, and parts quality are what you would see in s $4-5000+  Loudspeaker. Since I bought my
New Martin Logan Impression speakers  which are Big  she - my wife wants these speakers out ASAP.
Since she gave me $$ towards the new speakers I will comply.
I am just over the CT- Mass. Boarder I even have matching Supra Loudspeaker cables awg13, -7ft pr
That I would sell for $50 with the speakers, same brand that the speakers are wired with 5-9s pure  Copper.
Audiophile58
Any questions give me a call I will be on vacation all 4th of July week  only 4ft long they would fit in sny average sized car. Tel- 508-755-0870.
