VMPS RM40 Question
0 Members and 1 Guest are viewing this topic. Read 1681 times.
RoadTripper
VMPS RM40 Question
« on: 28 Jun 2017, 11:32 pm »
Because it hasn't seemed readily available in my searches, can someone answer this question:
What is the sensitivity and the nominal impedance of the RM40 (in stock configuration)?
revg1952
Re: VMPS RM40 Question
« Reply #1 on: 29 Jun 2017, 12:31 am »
Hope this Helps.
Specifications
Bass:   - 25 cm (10") WCF Megawoofer bass, 25 cm (10") WCF midbass, 25cm (10") Passive Radiator
Mid:   - four rectangular 10 x 20 cm (4 x 8") Neo ribbons, 280 Hz - 6.9 kHz
Treble:   - FST, 6.9 kHz - 30 kHz
Impedance & Sensitivity:   - 4 Ohm (3.6 min.) 90 dB/1W/1m
Power handling:   - 500 W rms / 4 Ohms, 20 W min.
Frequency response:   - 24 Hz - 25 kHz +0/-3 dB
Dimensions & Weight:   - 168H x 32W x 43D cm, 109 kg (66"H x 13"W x 17"D cm, 240 lbs)
Output levels and distortion:   - max. 1% THD fullrange / 1W, max. 115+ dB SPL / 1m
Finishes:   - standard lite oak, dark oak. Optional MLS african ebony, maple, birch, rosewood, walnut
Stimpy
« Reply #2 on: 30 Jun 2017, 07:09 pm »
You can find the VMPS Legacy website here.
http://pointillistic.com/vmps-audio/index.htm
At least it contains all the specs for the final series of VMPS speakers.  Info on models prior to this is difficult to find.
audiomagnate
« Reply #3 on: 2 Jul 2017, 12:57 pm »
...Info on models prior to this is difficult to find.
I'll say! Technical manuals like Harman did for the entire infinity line would be awesome. My gut tells me that 90 dB sensitivity figure is about right. Revg1952, did you win the auction on eBay for the RM=40's? My system uses the same mid and high drivers and I have some tips on driver integration/crossover points if you're interested.
revg1952
« Reply #4 on: 2 Jul 2017, 05:09 pm »
Sorry it wasn't me didn't know there was  a current bidding war. Happy listening to the winner
RevG1952
