0 Members and 1 Guest are viewing this topic. Read 3795 times.
After all when an amp clips because it can't put out more juice, is it not the squareness of the waveform that causes the speaker magnet to shear off the cone?
My two cents,for what its worth, is that you are probably clipping the amps. The Maggie 3.7i, or any maggie, will only play just so loud. After a certain point they quit getting louder because you have reached the limit of the diaphragms excursion. At this point more power goes in and not much happens but blown fuses or burned panels in extreme cases.
It's a couple of factors... clipping causes "square" waves which actually creates all sorts very high frequency content which then get magnified. This can force the speaker cone/film to move much faster than it can handle. This can cause your amp to oscillate. This can cause your amp to overheat and behave erratically. This can cause your speakers to burn out (that electrical energy is no longer going to mechanical motion and instead holds and dissipates as heat). All of these are bad mojo and can let out the magic smoke.
I also spoke w a hifi dealer near me. He said he's heard that the fuses start to blow when tweeters start dying. Something about the membrane causing short circuits.
How does an amplifier specified with voltage gain of 26db (x20) and 2 volts required for full output achieve a 1600wpc/8ohm power rating???The 26db gain and 2 volts tell me this amplifier clips at 40VRMS. That's a 200wpc/8ohm rating, yes???Dave.
http://sanderssoundsystems.com/products/amplifiers/magtech-monoblock-ampIf the above link is the amplifier that the OP is using then I agree with Davey. There is a spec here that doesn't make sense. I really wonder what the rail voltage is on this amp.
Anyway, I put a piece of tape on the preamp to remind me not to exceed the threshold.
