IDA-8 Question...
0 Members and 1 Guest are viewing this topic. Read 2510 times.
DanM66
IDA-8 Question...
« on: 21 Jun 2017, 01:05 am »
I just picked up a IDA-8.  I have a portable hard drive with a lot of high res music on it.  Without using a computer does anyone have any recommendations for a unit that I could simply plug the hard drive into and then connect to the amp.  Preferably with a screen.  Just looking for recommendations..
agdev01
Re: IDA-8 Question...
« Reply #1 on: 21 Jun 2017, 04:23 am »
Raspberry Pi+touchscreen and USB hub to power the drive would probably be the cheapest option.
in1unison
« Reply #2 on: 21 Jun 2017, 02:25 pm »
@ DanM66
You can also check Sonore products (from $300 retail). You can than use Roon to stream music to IDA. If you don't want to subscribe to Roon, all their devices come with BubbleUPnP, so you can use smartphone or tablet as a control device.
http://www.sonore.us/Sonicorbiter.html
Alternately if you plan to spend $500 or more, I would go for one of the Win 10 tablets, like Asus Switch Alpha 12 that retail from $600.
https://www.acer.com/ac/en/US/content/models/laptops/switchalpha12
srb
Re: Streamer for use with portable HDD - Recommendations?
« Reply #3 on: 21 Jun 2017, 03:20 pm »
Not really a Nuprime IDA-8 question (and if it was, not a descriptive title).
More appropriate would probably be something like "Streamer for use with portable HDD - Recommendations?" in The Discless Circle.
RafaPolit
    • www.rafaelpolit.com
« Reply #4 on: 21 Jun 2017, 10:28 pm »
Wouldn't the Omnia work for this as well?
DanM66
« Reply #5 on: 22 Jun 2017, 02:19 am »
Thanks for the advise, the Omnia does seem like the perfect fit...
