DanaCables USB 2.0m - $499
0 Members and 1 Guest are viewing this topic. Read 584 times.
audioguy213
« on: 19 Jun 2017, 11:10 pm »
This is the best USB cable I could find, period
I no longer need USB, so it goes to an appreciative new owner,
this cable is as good as it gets,
http://www.enjoythemusic.com/magazine/equipment/0915/DanaCable_USB_Cable_Review.htm
$895 new, mine is about 1.5 years old, I am the second owner,
Early B.
Re: DanaCables USB 2.0m - $499
« Reply #1 on: 20 Jun 2017, 01:31 am »
I have a pair of Danacable ICs. If the USB cable is as good as their ICs, then this is a great deal.
audioguy213
« Reply #2 on: 22 Jun 2017, 04:15 pm »
this USB cable can be considered either
life changing
or perhaps
system defining
if you have an audio system of carefully selected components,
and you are using any other USB cable, you are making a huge mistake.
You don't really know what your speakers, amp, or digital front end can do without this cable,
I have many $$$$ amps, speakers, components, and cables, and this is my favorite bang for the buck.
