Integra 50.2 receiver -- cheap price and nice
0 Members and 1 Guest are viewing this topic. Read 3953 times.
zieglj01
  • AV Trekker
« on: 16 Jun 2017, 06:54 pm »
Bought this refurbish from AC4L -- got it for $249 shipped. The price is $299 -- however, when you put it in the cart it deducts 20% -- use to list for around $1400 in 2011. I do not need 4k and HDMI 2.2 or Atmos -- so it was a no-brainer for me.
Easy to set up and the sound is clean and clear with low distortion -- picture through HDMI is really nice at 1080p. This thing is powerful and has a lot of headroom.
Sound and vision test >
the DTR-50.2’s left channel, from CD input to speaker output with two channels driving 8-ohm loads, reaches 0.1 percent distortion at 147.4 watts and 1 percent distortion at 172.4 watts. Into 4 ohms, the amplifier reaches 0.1 percent distortion at 200.4 watts and 1 percent distortion at 259.8 watts.
Lots of power in surround mode >
Five channels driven continuously into 8-ohm loads:
0.1% distortion at 110.8 watts
1% distortion at 134.1 watts
Seven channels driven continuously into 8-ohm loads:
0.1% distortion at 107.5 watts
1% distortion at 127.7 watts
http://www.accessories4less.com/make-a-store/item/intdtr502/integra-dtr-50.2-7.2-ch-x-135-watts-thx-networking-a/v-receiver/1.html
Phil A
Re: Integra 50.2 receiver -- cheap price and nice
« Reply #1 on: 16 Jun 2017, 07:30 pm »
Great Find!
milford3
« Reply #2 on: 16 Jun 2017, 08:03 pm »
Great Find!
+ 4 on this find. :thumb:
pinkfloyd4ever
« Reply #3 on: 17 Jun 2017, 03:03 pm »
Hmmm. I know very little about the home theater side of audio, but I'm looking to set up a simple 5.1 system. Are Integra A/V receivers much better than Pioneer, Yamaha, Onkyo, etc?
If so, any reason not to get the DTR-20.4 for $160? I have a small room and am only going to have a 1080p TV
srb
« Reply #4 on: 17 Jun 2017, 03:08 pm »
Are Integra A/V receivers much better than Pioneer, Yamaha, etc?
No.  Just another choice.
The various models I've seen seem to run a bit hotter than the other brands, even the pre-pros, but I can't say that exists with each and every model.
zieglj01
  • AV Trekker
« Reply #5 on: 18 Jun 2017, 07:04 pm »
Integta is part of Onkyo -- the 20.4 will serve your needs and is hard to beat at that price -- it tends to come down to overall preference, as I have owned Marantz, Denon, Pioneer, Yamaha, etc., and I prefer the Integra -- for me, they tend to be more clean, clear, and less distorted  when listening through the speakers. My 50.2 is not running hot, however give it room to breathe
