FS - Classic Harman Kardon TA260 TUBE receiver - Mint
0 Members and 1 Guest are viewing this topic. Read 5971 times.
dee1949
****************************  Pick UP in Washington DC 20017  ********************************
From a Retirement SALE !!!  - $625.00
... MINT Harman Kardon TA260 "Stereo Festival II" Receiver - recently serviced !!!
- 30 watts per channel
- Original condition (no modifications), excellent shape
- Similar to the Fischer Tube Receivers of the day. For a lot less money !!!
- comes with 2 spare matched GE power tubes - just in case. ( check bottom of ad )
-Nice heavy iron! Push Pull oriented output transformers
This unit weighs just over 40 lbs!
-Integrated Stereo Amplifier stage tube set:
3x12AX7, 1x12AU7, 4x7355 (3xecc83 - 1xecc82 - 4x7355 )
-Tuner stage tube sets:
AM-6BA6, 6BE6, 6EQ7
FM-2xECC85/6AQ8, 3x6AU6, 1x6AL5
with two EM84 "eye" tubes for tuning
-Great control features: volume and tone controls for each channel, switched RIAA (phono) or NARTB (tape) equalization -IN/OUT switches for tone control and equlization features
-Multiple inputs (1-Aux IN, 1-tape IN 1-tape-OUT, 2-switched MM phono IN)
*Great adjustable impedance headphone output stage (standard 1/4" jack)
-Versatile speaker outputs for 4,8 or 16 ohm impedance with phasing switch
-All excellent tested quality vintage tubes.
-Factory Harman Kardon Signature brown color metal case
........... Two spare GE power tubes for backup !!!
AMPLITREX TESTED & Nicely Matched Pair of GE 7355 Power Amplifier Pentode tubes.
 One of the tubes is labeled for Stromberg-Carlson (1966).
Both tubes feature grey plates, a side-mounted "D" style getter, and clear tops.  Test STRONG!
Results:
TUBE 1:  6,800 mhos (89%) / 52.5 mA (85%)
TUBE 2:  6,950 mhos (91%) / 55.8 mA (90%)
NEW spec average for this type is 7,600 (100%) / 62.0 mA (100%).
....also listed here is a Mint Dual 1009-F  (1019 ) turntable. Has 3 headshells and Vintage cartridges w/new stylus
- plus single, multi stack spindle for 33/78 and hard to find 45 stack spindle. With new nylon black cover
... Would take a lot of " TIME " and money to put together a vintage system like this !!!!!
... Awesome components to match to your VINTAGE speakers of the day !!!!!!
- Large Advents
- Dynaco 25 & 35
- Ar 2 thru 4
- etc.....
« Last Edit: 15 Jun 2017, 02:12 am by dee1949 »
dee1949
Re: FS - Classic Harman Kardon TA260 TUBE receiver - Mint
« Reply #1 on: 15 Jun 2017, 02:13 am »
... Comes with Two AMPLITREX TESTED & Nicely Matched Pair of GE 7355 Power Amplifier Pentode tubes.
Results:
dee1949
dee1949
« Reply #3 on: 23 Jun 2017, 02:40 am »
.. Also just listed a "RARE"  - Harman Kardon - Coronet - tube receiver.
http://www.audiocircle.com/index.php?topic=151096.0
« Last Edit: 25 Jun 2017, 06:33 pm by dee1949 »
dee1949
« Reply #4 on: 19 Aug 2017, 05:23 pm »
- TA260 Harman Kardon available -  $595.00
dee1949
« Reply #5 on: 17 Sep 2017, 05:55 am »
 Both tube receivers still available. Just in time for your long Winter nights of  Music listening !!!
