FS Audiophile/Collector Dual 1009-F (1019) Turntable - HK TA-260 tube receiver
0 Members and 1 Guest are viewing this topic. Read 6612 times.
dee1949
****************************  Pick UP in Washington DC 20017  ********************************
From a Retirement SALE !!!  Dual Turntable w/3 headshells w/cartridges & new stylus - Price - $525.00
... If you are an Audiophile ( 33 1/3 rpm ) or just into old 78 or 45 recordings ??? this is a GEM!!!
- Break out your 45 and 78 record collections. Stack spindles included.
- pour yourself a nice wine or cognac, light your favorite cigar.
- Stack up your favorite "OLD" 78's and 45's. Relax and ENJOY !!!
Hard to believe that after 45 plus years it could look and sound as good as it does.
Got to hand it to German engineering !!! Built like a tank !!!
This is the Dual 1009-F turntable. Last of the evolutionary line of the 1009 series, with preferred Black and Silver.
It was the top of the line in its day. And it was well regarded.
This model has the newer tone arm and headshell and evolved to become the 1019 model. Gray and silver.
Everything you need to know about it and downloads below:
https://www.vinylengine.com/library/dual/1009.shtml
... similar to below on youtube:
https://www.youtube.com/watch?v=CyU-VbHVt9E
.... how to set up your Dual turntable on youtube below:
https://www.youtube.com/watch?v=tSDPINYQ72c
............. What is included below:
- includes single, multi 33/78 stack spindle and hard to find 45 stack spindle.
- includes 2 vintage and 1 NEW headshells for easy swapping.
- includes - 3 Vintage cartridges w/new stylus for different listening experiences
AUDIO TECHNICA TR420E CARTRIDGE with new upgraded .003x007 elliptical stylus and headshell
Pickering V-15 Cartridges with new conical stylus and New headshell
Shure M93E cartridge with new 78 stylus and headshell
- Also included is a NEW black nylon dustcover to keep it dust free and safe.
- This Dual 1009-F was stored behind doors in a Stereo cabinet.
- only used occasionally after the introduction of cds.
- Like New !!!!.... as MINT as you will find, and ready to enjoy !!!
The Dual 1009-F is a work of ART. Art is always guaged and appreciated for its creation in its time frame.
View the underside and take it to an engineer to explain its complexity and breakthrough design.
Today it would cost many thousands of dollars to reproduce a Vintage Dual.
Collectors love them for their durability and sound.
Also due to their popularity, their are a ton of used and new parts available.
Specifications
Drive: four-pole, single-phase, induction motor
Turntable speeds: 78, 45, and 33 1/3 rpm
Platter: 4lb, non-magnetic
Wow and flutter: less than 0.12%
Rumble: less than 38dB below signal level
Signal to noise ratio: less than 56dB below signal level
Tonearm: balanced on all three axes, extremely low mass, and precision, friction-free suspension
Pick-up cartridge: tonearm will accept all cartridges with 1/2" mounting and weighing from 1-12g
Owners manual is available at Vinylengine.com.
..... and for the ULTIMATE listening EXPERIENCE , add The Harman Kardon TA260 TUBE receiver below:
... MINT Harman Kardon TA260 "Stereo Festival II" Receiver - recently serviced !!! - $625.00
-30 watts per channel
-Original condition (no modifications), excellent shape
- Similar to the Fischer Tube Receivers of the day. For a lot less money !!!
- comes with 2 spare matched GE power tubes - just in case.
-Nice heavy iron! Push Pull oriented output transformers
This unit weighs just over 40 lbs!
-Integrated Stereo Amplifier stage tube set:
3x12AX7, 1x12AU7, 4x7355 (3xecc83 - 1xecc82 - 4x7355 )
-Tuner stage tube sets:
AM-6BA6, 6BE6, 6EQ7
FM-2xECC85/6AQ8, 3x6AU6, 1x6AL5
with two EM84 "eye" tubes for tuning
-Great control features: volume and tone controls for each channel, switched RIAA (phono) or NARTB (tape) equalization -IN/OUT switches for tone control and equlization features
-Multiple inputs (1-Aux IN, 1-tape IN 1-tape-OUT, 2-switched MM phono IN)
*Great adjustable impedance headphone output stage (standard 1/4" jack)
-Versatile speaker outputs for 4,8 or 16 ohm impedance with phasing switch
-All excellent tested quality vintage tubes.
-Factory Harman Kardon Signature brown color metal case
... Would take a lot of " TIME " and money to put together a vintage system like this !!!!!
... Awesome components to match to your VINTAGE speakers of the day !!!!!!
- Large Advents
- Dynaco 25 & 35
- Ar 2 thru 4
- etc.....
« Last Edit: 16 Jun 2017, 03:54 am by dee1949 »
Letitroll98
  • Too loud is just right
Uhmmm, price?
I will accept this HK receiver as donation.
Whitese
That HK uses I think a tougher output tube to find (7355)?..Some people rewired for 6L6, or some say Sovtek 7591xyz thingy might replace the origonal outputs..
dee1949
.. comes with two AMPLITREX TESTED & Nicely Matched Pair of GE 7355 Power Amplifier Pentode tubes.  One of the tubes is labeled for Stromberg-Carlson (1966).  Both tubes feature grey plates, a side-mounted "D" style getter, and clear tops.  Test STRONG!
Results:
TUBE 1:  6,800 mhos (89%) / 52.5 mA (85%)
TUBE 2:  6,950 mhos (91%) / 55.8 mA (90%)
NEW spec average for this type is 7,600 (100%) / 62.0 mA (100%).
vkohl
Would love to get this Dual , will be coming to Capital Audiofest in November, but I guess you won't wait that long?
vkohl
no response ?
dee1949
... Still available -  $495.00 on pick up in DC
