buying a sony drive
0 Members and 1 Guest are viewing this topic. Read 3185 times.
redbook
  • the music is the blood...........
buying a sony drive
« on: 11 Jun 2017, 05:01 pm »
James can I purchase the sony drive that's used in the  BCD3 as assurance for future repairs. It would feel good having a spare unit on hand to avoid the dilema I  face now with the  BCD1...thanks... :thumb:
  • The Demo is Everything!
    • http://www.bryston.com
Re: buying a sony drive
« Reply #1 on: 11 Jun 2017, 06:55 pm »
Yes some people actually bought extra Phillips drives when we had them.
james
redbook
« Reply #2 on: 11 Jun 2017, 08:04 pm »
 Thanks James....Do I just go to my local dealer to order ?
« Reply #3 on: 11 Jun 2017, 08:18 pm »
No that would be direct from us. - I believe we are using a SANYO drive though not the Sony.  I will check.
james
redbook
« Reply #4 on: 11 Jun 2017, 08:42 pm »
Perhaps I read it it wrong when you posted it earlier but I thought it was a Sony. Thanks for checking...Those metal guide rails seem to say that it's a very smooth and well supported tray movement....much loke on my old Sony Es700.
redbook
« Reply #5 on: 11 Jun 2017, 08:53 pm »
 I found the Sony number on an earlier post July 2016....the drive chosen was the Sony  KHM 313....if it's aSanyo now  when did it change ?  thanks again James.
« Reply #6 on: 11 Jun 2017, 09:20 pm »
I will ask engineering but I think we changed it before production started.  Or it might be a Sony drive with a Sanyo laser assembly.
james
redbook
« Reply #7 on: 12 Jun 2017, 12:36 am »
Thanks again James. I never thought these things could be customized and tailored. :lol: Why would the laser be different from the drive? Is the Sanyo a better choice for reliability ? In the future, if Sanyo decides to cop out, could we still purchase spare units from you? I guess I'm a bit paranoid about that  Phillips deal leaving my otherwise great BCD1 player useless....don't want that to happen again if possible... :thumb:
« Last Edit: 12 Jun 2017, 02:32 am by redbook »
rmurray
« Reply #8 on: 12 Jun 2017, 12:52 am »
 Any special reason why it may have been changed to a Sanyo from the Sony? :scratch:
Phil A
« Reply #9 on: 12 Jun 2017, 03:06 am »
For those into disc spinners, getting these spare parts is a great idea.  I finally sold my LD players about a year and a half back.  I got rid of everything, including discs and the extra spare parts (e.g. spindle motor).  I had two players, a Pioneer Elite CLD-79 and a Pioneer 704.  They are essentially the same machine.  I did that on purpose.  I had them in two separate systems but figured between the spare parts and extra player with the parts that I could keep it running for a very long period of time.
redbook
« Reply #10 on: 12 Jun 2017, 05:57 pm »
james
james, why was it changed to a sanyo ? :scratch: Did you consider the Sanyo was a better unit for the new player ?
spinner
« Reply #11 on: 13 Jun 2017, 05:31 pm »
.....James  is the drive shown in the web site picture ( the one with metal guide rails) the Sony or the Sanyo ?.....thanks.
CanadianMaestro
« Reply #12 on: 13 Jun 2017, 05:36 pm »
Probably more easily available in abundance for future-proofing.
« Reply #13 on: 13 Jun 2017, 05:39 pm »
OK I have the straight goods.
There never was a Sony drive - just the Sony Laser.
We buy the drive from Stream Unlimited and they originally used the Sony Laser but now use the Sanyo laser due to availability.
The good thing is that Stream Unlimited manufactures the drive and a lot of manufacturer's use it so it looks like it will continue to be manufacture for many years to come.
As always there are no guarantees with technologies that are no longer supported by mainstream manufactures.
james
« Reply #14 on: 13 Jun 2017, 05:39 pm »
Its the Stream Unlimited drive.
Comes in Metal or Plastic versions - we use the metal one.
james
rmurray
« Reply #15 on: 13 Jun 2017, 05:43 pm »
Thanks  james...so when I order a unit it will be with the metal guides ?. I just feel that it's sign of good build quality...makes feel good inside...
« Reply #16 on: 13 Jun 2017, 05:56 pm »
Yes all our drives have the metal guides.
james
rmurray
« Reply #17 on: 13 Jun 2017, 09:26 pm »
 Thanks  James. I just came back from the HiFI Center here in vancouver...most pleased by the player, very nice. Both  Dennis and Greg were most  helpful ....Hope to see  Chris  Russell at the upcoming open house.....are you visiting us as well ? :thumb: P.S....looking forward to ordering a unit ( in  black of course .....goes with my socks    LOl :lol: :thumb:
redbook
« Reply #18 on: 13 Jun 2017, 09:32 pm »
 Yes thankyou for taking the time James ...appreciate it  :dance:
« Reply #19 on: 13 Jun 2017, 10:07 pm »
Hi
Its Brian Russell who will be at the show - sorry I could not make it.  Glad you liked the player.
james
