0 Members and 1 Guest are viewing this topic. Read 2971 times.
Hi all,I currently have the VSA VR-5 HSE soon to be VR-5 Anniversary MKII. I have a McIntosh MC452 amp that has 4 and 8 ohm taps. Does anyone use the 8 ohm tap for the Mid/Tweeters and the 4 ohm tap for the woofers?ThanksPaul
Hi Paul,I have the exact setup as you, McIntosh MC452 with VR-5 Anniversary MKII's!! My Signature Mastrrbuilt cables are hooked to the 8 olm load. Sweet music indeed!Henry
Hi Paul,I use both 8 ohm's for both! Sounds good as is! Where are you located? I'm in Linthicum Maryland, just outside of Baltimore by BWI airport. Would love to show up my setup!Henry
Thanks guy's! Just received a reply from Chuck Hinton at McIntosh. "Yes, for 3Db more bass, hook the woofers to the 8 and the Mid/tweet to the 4"
