x-voce paired with martin logan?
0 Members and 1 Guest are viewing this topic. Read 2519 times.
BobC
« on: 30 May 2017, 06:15 pm »
Hi guys.
I have Martin Logan Ascent i main speakers, currently paired with a B&W CC6 center.
Sounds ok, but I'm looking into options to update the center, but cant justify the cost of a matching ML center.
I'm pretty handy and would be willing to try DIY kits, so the x-voce is intriguing.  Curious to know if anyone has experience here, specifically if it'll be a decent match with the electrostatics.
Is it possible to spec the tweeter for a better match?
Thanks, Bob
Danny Richie
Re: x-voce paired with martin logan?
« Reply #1 on: 31 May 2017, 02:37 am »
The X-Voce might match with them pretty well especially in the vocal region.
And I wouldn't worry about that tweeter too much. It is one of the best dome tweeters out there and won't be out shined by your ML's.
Plus I still have fully assembled X-Voce models marked down to $250 a piece.
« Reply #2 on: 31 May 2017, 03:12 pm »
I think these  are the ones  Danny is referring to, not sure which  versions he has left but they  all  look  fantatic
http://www.audiocircle.com/index.php?topic=95858.msg958492#msg958492
jay
Coldfusion
« Reply #3 on: 2 Jun 2017, 12:51 am »
Which finishes?  Any black?
Danny Richie
« Reply #4 on: 2 Jun 2017, 01:27 am »
I still have about everything except black.
Chops
« Reply #5 on: 11 Jun 2017, 09:52 pm »
The ONLY thing I miss about running a multi-channel system is the X-Voce. Mine is all original and I matched it up to quite a few different speakers with near perfect tonal balance. It's an excellent center channel and I wouldn't hesitate for a second to integrate it with my current Martin Logan SL3's. I know the X-Voce would match it perfectly. No question about it.
dlynch34
« Reply #6 on: 21 Oct 2017, 07:51 pm »
any x-voce still in stock by chance?
Danny Richie
« Reply #7 on: 23 Oct 2017, 03:59 pm »
Yes, and what's left is listed right here: http://www.audiocircle.com/index.php?topic=89801.msg885323#msg885323
