Which 5751 is best for a Phono Pre-
0 Members and 1 Guest are viewing this topic. Read 3260 times.
bebop86
« on: 29 May 2017, 02:26 am »
Need to change my 5751 tubes in my joule electra OPS-1- which tube is the best or highly rec. for a phono preamp- thanks
thorman
Re: Which 5751 is best for a Phono Pre-
« Reply #1 on: 29 May 2017, 10:48 am »
To me the best all around 5751 is the GE 3 mica Black plate...Other 5751's are also great, but found the GE to have the best balance all around...
strateahed
« Reply #2 on: 30 May 2017, 04:18 am »
+1   what thorman said. Love those GE's.
« Reply #3 on: 30 May 2017, 11:01 am »
Mr.Judson Barber will advice you with great experience.
dminches
OzarkTom
« Reply #5 on: 30 May 2017, 08:00 pm »
That one is my favorite.
Manolo
  • Consulting Structural Engineer
« Reply #6 on: 30 May 2017, 10:56 pm »
Or Sylvania black plate 3 mica spacer....
rotarius
« Reply #7 on: 18 Jun 2017, 05:06 am »
Can't go wrong with any of the tubes already mentioned.  Let's not forget the RCA black plates as well.  I just rolled in the GE 3 mica black plates a few days ago and yes it has more oomph than others but I found them to be a bit less refined than the RCA in the upper mids.
earwig
« Reply #8 on: 10 Jul 2017, 09:30 am »
I used to like the Jan/Sylvania white box on my Conrad Johnson.
syzygy
Pryso
« Reply #10 on: 10 Jul 2017, 05:21 pm »
bebop,
Jud is retired and not likely to reply.
Without commenting on a specific brand, I was a beta tester for Joule in the early years and we discovered the 5751s with asymmetrical plate -- 2 punches one side and 1 on the other -- sounded best overall.
