Roon Volume Leveling
0 Members and 1 Guest are viewing this topic. Read 3309 times.
jtwrace
    • TIPP YouTube Channel
« on: 23 May 2017, 02:21 am »
I finally caved and enabled it and boy am I glad I did.  No more constantly adjusting the volume with the remote.  Pretty much find myself just listening at the same volume all the time which is SO nice.
Some screen shots...
https://kb.roonlabs.com/Volume_Leveling
SFDude
Re: Roon Volume Leveling
« Reply #1 on: 23 May 2017, 03:12 pm »
Thanks for the tip. Just enabled it myself and liking the CONSISTENT in volume levels across all digital sources (FLAC, DSD/DSF and Tidal).  :thumb:
jtwrace
« Reply #2 on: 23 May 2017, 06:41 pm »
You're welcome!  Yes, it's quite nice and I find myself listening at more reasonable levels too and not messing with the level every track.   :thumb:
firedog
« Reply #3 on: 24 May 2017, 06:14 am »
No one is finding that is dulls the sound a bit?
When I tried it in the past that is what I found.
jtwrace
« Reply #4 on: 24 May 2017, 02:14 pm »
Not at all.  It drops the SPL so you might need to adjust the volume level up to get more SPL but as far as degrading the sonics?  Nope.
goskers
« Reply #5 on: 24 May 2017, 02:24 pm »
I changed my settings last week and then turned it off again.
It does drop the overall level so this needs to be adjusted.  I can't say I have heard any difference other than the overall level being lower.
jtwrace
« Reply #6 on: 24 May 2017, 02:26 pm »
That's how it's supposed to work though.  You can click on album info and it will tell you how much it drops each album by.
slefley
« Reply #7 on: 25 May 2017, 07:14 pm »
jtwrace - thank you for starting this thread.  I live in a condo and try to control the volume so I don't irritate my neighbors and it was driving me crazy to adjust the volume between just about every track.  I enabled Volume Leveling and so far every track I've played has the same peak volume (within a dB or so).  Naturally this means that on tracks with a wide dynamic range the quiet parts may be a lower volume than I'd prefer (since the VL function seems to set the maximum level), but at least I can just enjoy the music without worrying about blasting the neighbors.  Sooo much better!!  Thanks again.
jtwrace
« Reply #8 on: 22 Jun 2017, 02:08 am »
Glad it's working for you.   :thumb:
