Munich 2017
0 Members and 1 Guest are viewing this topic. Read 1851 times.
  • The Demo is Everything!
    • http://www.bryston.com
Munich 2017
« on: 17 May 2017, 06:13 pm »
james
CanadianMaestro
Re: Munich 2017
« Reply #1 on: 17 May 2017, 08:19 pm »
Nice booth! Was that flown over or local?
Is that James back there looking for the Lost Ark?
Re: Munich 2017
« Reply #2 on: 17 May 2017, 08:23 pm »
It's local - our German distributor.
Ola_S
Re: Munich 2017
« Reply #3 on: 17 May 2017, 08:59 pm »
Maybe I should go to Munich after all, it would nice to hear some Bryston speakers for the first time. It just a 1,5h drive from where I live so I do not really have any excuses  :D
Re: Munich 2017
« Reply #4 on: 17 May 2017, 10:13 pm »
Hi Ola
Yes go for sure - I would be very interested in your thoughts on the Mini T's.
james
TJ-Sully
Re: Munich 2017
« Reply #5 on: 18 May 2017, 05:03 am »
Ola - i agree, you should most definitely listen to the Mini T's.
I have a pair of Mini T's in my system and, after 2 years, are still loving them! stunning bass and you can listen at amazing levels with absolute clarity. you can listen for hours without a hint of fatigue. Just beautiful.
James, I'm curious how far apart the Mini's are spaced in the above photo, whether they are toed in a tad, and also distance to the listening position.
thanks!
Sully
Re: Munich 2017
« Reply #6 on: 18 May 2017, 09:57 am »
Re: Munich 2017
« Reply #7 on: 18 May 2017, 10:00 am »
thanks!
Sully
Hi Sully
I am not in Munich so not exactly sure how far apart they are.  They look look like they are facing straight forward and the recommended distance in a room that small would be about 6-7 feet.  The Mini T's have very wide dispersion so there is a lot of flexibility in placement.
james
Re: Munich 2017
« Reply #8 on: 18 May 2017, 01:02 pm »
james
Anthony D'Ascanio
Is that James Tanner?
Master at setup!!!
