Heathkit W5M Mono Amplifiers (Restored) & matching Preamplifiers - VG Cond $1250
0 Members and 1 Guest are viewing this topic. Read 4226 times.
apt_one
Almost sixty year old Heathkit W5M mono amps are in excellent condition, see photos. $1250 plus shipping and paypal fee.
This pair of clean Heathkit WM-5 tube mono block power amps with cages and matching tube preamps, these have the highly desired peerless 16458 transformers, output tubes are sovtek 5881/6L6WGC. Preamp knobs don't match between units, one cage on power amp is missing logo. You can find a matching sets of preamp knobs on eBay easily. Wonderful sounding and comes with those great transformers (they do not make them like this anymore.)
Was told by the previous owner that the amps have the Vacuum Tube Valley capacitor upgrade.
See photos to verify if you know about it. All units were checked and in good operating order. This is a plug and play system. Sold without any kind of warranty or returns. Will pack well with tubes removed from their sockets. You'll love the sound of these classic amps!
High bidder will be very pleased. If paying via paypal, please add 3% to total, money orders and cashiers checks accepted too with no surcharge.
Actual fedex shipping rates will be charged. I will pack all well so they arrive safely to you.
Email me at [email protected]
Here is a copy of the manual:
http://www.mcmlv.org/Archive/HiFi/HeathkitW5M.pdf
The W-5M Amplifier is considered top value in its power class by leading independent research organizations. It incorporates all the latest advance-design features for the super-critical listener. You can enjoy virtually distortionless reproduction from one of the most outstanding high fidelity amplifiers available—at any price! This amplifier employs a specially designed Peerless output transformer and uses KT66 tubes. Involving entirely new techniques in transformer design, this Peerless unit prevents loss in frequency response, especially at moderate volume levels, in addition to allowing increased power output. The circuit is rated at 25 watts, and will follow instantaneous power peaks of a full orchestra up to 42 watts. Featured also, is the "tweeter saver" which suppresses high frequency oscillation, and a new type balancing circuit. This is easier to adjust, requiring only a voltmeter, and it results in a closer "dynamic" balance between output tubes. Overall results are improved phase shift characteristics, reduced IM and harmonic distortion, and improved frequency response. With complete stability under all dynamic operating conditions.
The frequency response of this amplifier is ± 1 db from 5 to 160,000 CPS at 1 watt and within 2 db from 20 to 20,000 CPS at full 25 watts output. Harmonic distortion is 1% at 25 watts and intermodulation distortion is 1% at 20 watts (60 and 3,000 CPS, 4:1). Hum and noise are 99 db below 25 watts for truly quiet performance. The specifications above were taken with the most modern and accurate test equipment available in 1958. They are actual measurements taken on a typical amplifier, under carefully controlled conditions, not representing the most favorable operating conditions nor advertising information.
All connectors and terminals are located on one side of the chassis apron for convenience. The circuit is fused, and two AC outlets are provided for accessory equipment. One outlet is switch-operated and can be used to automatically turn off record player motor when amplifier is turned off. Provision is made for matching 4, 8 or 16 ohm speakers at a terminal strip on the chassis. The chassis is finished in satin-gold enamel, and all terminals and tube sockets are marked as to type and function. An attractive cover fits over all above-chassis components. This not only "child-proofs" the unit, but it results in a most attractive "finished" appearance. The bottom plate also has large rubber feet to prevent marring of furniture. It is suitable for use in or out of a cabinet. Rich black and gold color harmonizes with the Heathkit model WA-P2 Preamplifier, the Heathkit model FM-3A Tuner, and blends with any room decoration.
Conservatively rated, high quality components are used throughout to insure years of trouble-free performance. Its specifications, completely outlined above, clearly indicate the superiority of this amplifier for the individual who wants "something special" in top-quality audio. The construction manual is written so that no technical background or training is required for assembly. Complete step-by-step instructions are provided for every stage of construction, and large pictorial diagrams illustrate exactly where each wire and component is to be placed.
Specifications—Power Output: 25 watts. Frequency Response: ± 1 db from 5 to 160,000 cps at 1 watt. Harmonic Distortion: 1% at 25 watts. Intermodulation Distortion: 1% at 20 watts (60 and 3,000 cps, 4:1). Hum: 99 db below 25 watts.  Damping Factor: 40:1. Input voltage for 25 watts output: 1 volt. Tube complement: 2-12AU7, 2-KT66, 1-5R4GY. Output Transformer: Peerless, Special Design. Power requirements: 105-125 volts, 50/60 cycles, 140 watts. Dimensions: 13 3/32" wide x 8½" deep x 8¼" high. Shipping Weight: 31 lbs.
« Last Edit: 30 May 2017, 09:35 am by apt_one »
apt_one
apt_one
Output transformers are peerless 16458.
apt_one
Output tubes are sovtek 5881/6l6 wgc. Thanks.
