Magnepan 3.6 midrange fuse bypass... (did it tonight)
0 Members and 1 Guest are viewing this topic. Read 1439 times.
Elizabeth
I have owned my Magnepan 3.6 for seven years.
Never a fuse blown. A few years ago I ran a wire across the fuses...
Tonigh I went into the backing plate and bypassed the fuse clip altogether.
I did a 'quick and dirty' pulled the push on off the bottom of the mid level fuse and snipped the end of the top wire so I could slide the bottom clip on the top wire. crimped it some
This seems the easiest way, and allows the reversal of the mod.
If I like it I will do a cleaner install.
No instant 'revelations'. I will have to listen for awhile to say if it mattered (to me)
The immediate response I would say maybe a slightly sweeter 'edge' here and there on some notes.
(CD, Smetana Quartet Beethoven Quartets..)
I.Greyhound Fan
Re: Magnepan 3.6 midrange fuse bypass... (did it tonight)
« Reply #1 on: 30 Apr 2017, 11:13 pm »
I tried AMR tuning fuses and they made things sound too bright.  Total waste of money.
Elizabeth
« Reply #2 on: 1 May 2017, 04:44 am »
I have a small coil in the resistor spot. I forget what the coil is called, but it is a tweak mentioned over at A.A. planar speaker asylum at some point.
It is a small wirewound coil. IMO better than a 1 ohm fuse.
Anyway, I had aftermarket fuses too. a few years ago I bypassed them with bits of wire from the outside.
Now I went inside.
I have to say I would not claim any difference unless I can prove to myself it is different... but yes I heard something I never noticed before on a CD I know pretty well. "The Indestrutible Beat of Soweto"
On one of the tracks I can hear (and never heard before enough to know what it was) pieces of metal being clanked together. This sound is well in the background, but now I can recognize it clearly.
This is one of those things that shows yeah something has been altered for the better.
It is a sound I would have remembered it was there if I could have recognized it before. (I have listened to this CD more than several dozen times..) Now maybe I heard something, but no way could I recognized WHAT it was. now it is clear what it is.
So the removal of the fuse matters to my ears. SUCCESS.
rollo
  • Rollo Audio Consulting -
« Reply #3 on: 1 May 2017, 02:01 pm »
  Worked out well for me when I owned Maggies. Another tweak was replacing the Nickel plated connectors on the outboard crossover with Cardas copper. Nickel was "bright" in direct comparison. Keep on trucking.
charles
