0 Members and 1 Guest are viewing this topic. Read 3156 times.
Nice find Steve!Best,Anand.
Thanks Anand. I may be beating a dead horse with this . Just trying to make my new Vista Phono-2 operate at its best.
Well going with an RCore is the right move here (if you are wanting to tweak). I like EI Core as well but they can be prone to hum, and with the right RCore if obtained with an electrostatic shield, you'll minimize capacitative coupling between the primary and secondaries with less noise issues. I try to avoid toroidal transformers for low level electronics. They are so wide-band that any interference, noise, pulses etc on the mains are transmitted to the secondary side almost un-attenuated. The advantages of toroids - smaller size and less stray fields - are secondary in my view, and those issues can be taken care of easier than trying to filter the mains junk. So RCore it is!Best,Anand.
Thanks Anand.I respect your advise and knowledge. I know you build your own components.All-tho I'm a 35 year audiophile, I don't know it all. Can you point be in the direction of an RCore 12vac supply?
Check out Teradak. They have a bunch of stuff. I use their 12V13A LPS.
The Astron is a DC power supply. WireNut is looking for a 12VAC supply.
...........so I can use my good power cord.
Huh? Let me guess.....your "good power cord" cost more than the Vista preamp did??It's unlikely you're going to improve the performance of this unit by simply changing out a wallwart. And there's certainly no need for a big, high current unit when all you need is 300 milliamps. In fact, the actual load is probably less than that.AC wallwarts are excellent for this type of application.If it ain't broke, don't fix it.Dave.
