0 Members and 1 Guest are viewing this topic. Read 25939 times.
Of course that's only when one remembers to put the amp in the low-power "Standby" mode in between listening sessions. Otherwise during normal "On" operation, whether a source is playing or not, low or high volume, it will have close to the 200W power consumption.That's just the price of Class A admission, like tube amps, but generally without the maintenance, adjustment or parts replacement.Steve
.......unless you're one who prefers to leave their system powered up ALL day and night. I don't see the point in that, because most electronics (except maybe some sensitive digital gear) these days will reach thermal stability in like 30 minutes to an hour max.
I think 24X7 amplifier power-on is pure silliness and wastefulness. Pass put in the low-power standby circuit (unlike some amplifier's standby circuits which only serve to keep trigger and remote control circuits active) to provide some output device biasing and keep sound capability at 100% for the purist.But even if I turn the whole thing on and off with a trigger (like brj), I don't mind operating at 95% sound quality for the 30 minute thermal stabilization period! Steve
My Primare PRE30 has an RCA-type socket providing 5V output for remote link.
Thank you very much! @I.Greyhound Fan noted: “Having high current and headroom makes a difference.” I understand you are referring to Amplifier headroom here? Could you please help me to find what the value of this parameter for XA30.5 is: to use the SPL Calculator “Amplifier headroom” parameter needs to be entered? For example, McIntosh MC452 has headroom of 1.8dB only. About current delivery: XA30.5 has Maximum Output Current of 20 Ampere. Is this enough for my Monitor Audio RS6 speakers? On heat dissipation. @srb estimated it at 680 BTU/hr. Under this condition BTU Calculator gives an estimate of 20 degrees Celsius. In my mind, this correlates with what was observed by @RDavidson: “If it raised the ambient room temperature, it didn't do so any more than maybe a 2nd person in the room would (due to body heat). The XA30.5 was never more than warm to the touch, not hot. … The XA30.5 produced negligible heat in comparison.” Would you recommend using external forced air cooling for XA30.5 (small desk fan, e.g.)? @brj, could you please explain what device I need to implement your approach of “… I use the 12V trigger inputs on mine, driven from my pre-amp.” My Primare PRE30 has an RCA-type socket providing 5V output for remote link. Yes, it’s a silly one, but this demonstrates you my level of experience… P.S. BTU Calculator can be found here:http://www.calculator.net/btu-calculator.html?roomwidth=1410&roomwidthunit=feet&roomlength=14&roomlengthunit=feet&ceilingheight=10&ceilingheightunit=feet&insulation=normal&temperature=20&temperatureunit=c&calctype=heat&x=30&y=9
...My “cave” is only 14x14x9! Should I be concerned? Mind you, I seldom, if ever listen at concert levels…
@srb noted “The trigger input on the XA30.5 will work over a range of 5VDC - 12VDC.” It is very important for me to have practical confirmation on the subject as one of the articles, “Trouble shooting for dummies”, on Pass Labs website suggests “The supplied voltage for the trigger is to be 12 volts direct current.” Thank you @srb!
Thank you all, as always! It is very reassuring to know the trigger will definitely work with my PRE30. Thank you @srb! @I.Greyhound Fan: Excellent find! S/N 1245 (as far as I can see from the picture) suggests it was manufactured sometime around the year of 2000. A bit dated, shall we say? @RDavidson: “… about looking at Mark Levinson is that they seem to burn through power supply capacitors rather quickly....ie less than 10 years of use, and maybe even closer to 5-7 years… ” I think I will pass this ML amp. I have just checked Reno HiFi, and found they have XA30.5 with the following description:"Used, Excellent condition, about two years old, one year transferable factory warranty, all factory accessories, new factory double-boxing, Satisfaction Guaranteed. S/N 28934. $3295. " Would you consider this to be a fair price, please? Last but not least… What amp stand would you recommend, please? My 17” stand will not be able to hold this little “monster”…
Last but not least… What would you consider to be a fair price nowadays for XA30.5 in excellent condition, please?
Another amp to consider if you want to buy new is this Vincent Audio [SP331MK]
