0 Members and 1 Guest are viewing this topic. Read 25941 times.
I'll weigh in on the trigger topic. While RDavidson gives good advice about amplifier power sequencing, it also depends on the equipment. Some components have built in muting delay and they also differ in turn-on and turn-off transients and power supply charging and discharge.While it's possible that some scenarios could damage a driver, I probably would personally give the trigger a try. If turn-on and turn-off noises are subtle, I would use the trigger. If they are not subtle, then I would revert to manual power sequencing and ditch the trigger.It obviously works in many scenarios or Nelson Pass wouldn't have provided the trigger connection.Steve
Thank you very much, dear friends! For now I will just "manually" follow what was kindly suggested by @RDavidson: "ALWAYS turn your amp ON last, and ALWAYS turn it OFF first." The beast has arrived, and now am waiting for a good neighbour of mine, a strong young gentleman, to come back home from his business trip and help me to unpack and set it up into my rack. Any final suggestions, please? Would you consider Pass Labs XP-10 to be the best solid state fully balanced preamp (operates in pure Class A!) under 3K used to work in tandem with XA30.5, please?
What is the purpose of Pass Labs XA30.5 meter, please? During my listening sessions the needle is always around 12 o’clock… What does this mean?
I'm not saying that's excessive standby power consumption necessarily, but if it is 15W standby, it is poor product copy in that by no one's definition is 15W a "few" watts and Pass should just publish the numerical spec.Steve
Thank you very kindly @mav52! Could you please help me to understand the differences between the "stock", Stage 1 Upgrade, and Stage 2 Upgrade? Which variant do you prefer? Would you recommend using a table fan (e.g. something like http://www.matthewsfanco.com/index.php?page=cinni) to cool XA30.5 down? Not sure if this even necessary...
