Multicell horn 3D printing
0 Members and 1 Guest are viewing this topic. Read 1716 times.
Grasho
« on: 24 Apr 2017, 12:32 pm »
Got an assignment to create a multicell horn using a 3D printer. Started using Fusion360.
Does anyone know how i could get specific dimesions for a multicell horn so i could draw it?
Re: Multicell horn 3D printing
« Reply #1 on: 24 Apr 2017, 12:46 pm »
Welcome Grasho :thumb:
A horn dimensions depend on the driver it will use, and the dB gain intended, its calc according the TS pars from the driver.
Phil A
Grasho
« Reply #3 on: 24 Apr 2017, 01:12 pm »
well ive had in mind to try to create a print of the altec H-808 horn, so i really dont know where to start.
« Reply #4 on: 24 Apr 2017, 01:18 pm »
Do you want the plan or already have it?
Grasho
« Reply #5 on: 24 Apr 2017, 01:23 pm »
Have no plan at the moment, thats why I could use some help.
Grasho
« Reply #6 on: 24 Apr 2017, 01:25 pm »
I guess the tractrix curve is going to be a problem to apply in the program..
« Reply #7 on: 24 Apr 2017, 02:38 pm »
Greetings & Welcome to AC Grasho   :thumb:
Grasho
« Reply #8 on: 24 Apr 2017, 05:11 pm »
Greetings mate
