0 Members and 1 Guest are viewing this topic. Read 13276 times.
Yup, and what's your point?
That no one's trying to make their mind up between these two. A useless comparison, imo.-Jim
Pez, the user manual actually suggests using it in mobile vehicle applications powered from 12V battery. So I contacted iFi technical support about using outboard 12V power suppplies in the home, and they provided the expected max current demand at 12V and said my plan should work fine.
Spec wise that might be the case, but sonics might become an issue. I have tried just that using the iCan SE which is rated for 15v I used a linear 12V. While it sounded better in some ways, it also killed dynamics and bass control. Your call, but it's a bit like putting a mule in place of a racehorse. Perhaps try both ways and report back. I'm curious to see what you' find.
Pez, the user manual actually suggests using it in mobile vehicle applications powered from 12V battery. So I contacted iFi technical support about using outboard 12V power supplies in the home, and they provided the expected max current demand at 12V and said my plan should work fine.
It is not an insignificant consideration, I guess, that a '12 V' car battery typically outputs 13.6 V.
