Dennis Had Inspire KT88 HO Single Ended Amp for sale
0 Members and 1 Guest are viewing this topic. Read 3253 times.
roscoe65
For sale is my lightly-used Dennis Had KT-88 HO single ended stereo amplifier.  I purchased this about a year ago but have now upgraded to one of his PSE amps at twice the price.  I now have more amps than I can use and it is time for some of my equipment to find new homes.
It is identical to the current model (http://www.ebay.com/itm/STEREO-TUBE-AMPLIFIER-INSPIRE-by-DENNIS-HAD-KT88-TUBE-SINGLE-ENDED-AMPLIFIER-/152441666455?hash=item237e3b3b97:g:7~kAAOSwIgNXokNy) in the same black and gold color scheme with the following two exceptions:  it uses a 6DJ8 family driver tube and does not have his latest IIPS power supply circuit (though Dennis will retrofit it if you like).  This version, without the IIPS is much more sensitive to rectifier changes, and you can really hear the difference between really nice rectifier tubes.
This amp will run almost any tetrode or pentode you can fit with or without adapters.  These include EL84, EL34, 6V6, 6L6, KT66, KT77, KT88, KT120, or KT150.  Output power runs from 5wpc with 6V6 to 12wpc with KT88.  This is a tube-rollers dream and a lot of fun.  It runs extremely quiet and while it sounds like a tube amp, it does not sound like what Dennis calls an "old man's amp".
The amp does like a bit of gain upstream, so a preamp or higher output DAC would be best with this.  I think a fantastic system would be an iFi iDSD Black, this amplifer, and a pair of Omega speakers.
Price:  $900, inlcuding Paypal fees and shipping within Conus.
R.
danabunner
Re: Dennis Had Inspire KT88 HO Single Ended Amp for sale
« Reply #1 on: 15 Apr 2017, 07:15 pm »
These are fantastic amps for the money.   12 wpc, single-ended, hand-built by a master (Dennis Had) amp for $900??!?   If I didn't already own two of his amps, I'd buy this one.  The 12wpc is significantly more than many single-ended amps, giving you a wider speaker choice.
roscoe65
« Reply #2 on: 15 Apr 2017, 07:38 pm »
I have three SE amps, which is one more than I can use right now.  If Dennis hadn't come out with his 20wpc PSE I would be keeping this amp.
They are indeed handcrafted and hand signed.
neep
« Reply #3 on: 8 May 2017, 05:23 am »
Just tried to PM you but it didn't go through.
Wanted to throw out an offer.
neep
« Reply #4 on: 13 May 2017, 11:30 am »
Was this user banned? I see "restricted" under his name and PM's won't go through.
