What exactly is the 215 sub?
0 Members and 1 Guest are viewing this topic. Read 1766 times.
warnerwh
« on: 2 Dec 2004, 01:33 am »
Does it have two active woofers. How about size?  Thanks
Brian Cheney
    • http://www.vmpsaudio.com
215
« Reply #1 on: 2 Dec 2004, 02:01 am »
The 215 has one active and one passive 15" and a builtin crossover for use with the RM30M.  Price is $650ea and size is the same as the New Original Sub.
jermmd
« Reply #2 on: 2 Dec 2004, 04:52 am »
What is the crossover set at and do the RM30's run full range with subwoofer augmentation?  Is there a subwoofer level adjustment or is that done through the amp?
Joe M
Brian Cheney
215
« Reply #3 on: 2 Dec 2004, 05:03 am »
The crossover is at 55Hz at 6dB per octave.  The RM30M's run full range, the woofer augments the first octave and a half.  To match levels I have been using the subwoofer out of the Trinaural Processor which adds a 12dB characteristic at 80Hz, accelerating the rolloff.
rblnr
« Reply #4 on: 2 Dec 2004, 04:00 pm »
Would this be the appropriate sub to use in a not medium/small room featuring RM40's and the LRC?
lifewithmusic
« Reply #5 on: 5 Dec 2004, 07:22 am »
Brian:  Any chance of James designing you an Ampzilla parametric equalizer to smooth room response with this and other subs?  And a calabration mic and video read out with the eq. would be great too.
Sedona Sky Sound
« Reply #6 on: 5 Dec 2004, 08:23 pm »
I don't see James doing that in this life but I have been wrong before  :oops: . His new pre-amp that is due out in the March/April timeframe will have a built-in equilizer. I think he said it had either 3 or 4 hinge points so it will not be appropriate for smoothing room response, just for further tweaking the sound to your personal taste.
Julian
www.sedonaskysound.com
