0 Members and 1 Guest are viewing this topic. Read 8114 times.
He,he,he....... There's no reason to drive yourself crazy over "Which Amplifier is Better than that Amplifier" as there probably "isn't" a definitive answer to the question. There are way too many variables at work,with the most important one being,we all have slightly differentlikes & dislikes.I hate to mention this over used term,but,it's all very Subjective to your individual listening needs. The Better question to ask is "Which Amp is the best "fit" (Unless you're considering changing everything ) for what I'm already using. You might be better off starting a discussion about what it is you like to listen to & what you like or dislike about what you're currently using !Just remember the old saying "A Bird in hand is worth two in the Bush" which means you'll have to try things for yourself (eventually)
Yes - they are worth it. No - not splitting hairs : bryston eg doesn't sound anything like a Jeff Rowland.
Buy something, plug it in, listen and enjoy. Don't worry about whether there is anything better --- there always is. Avoid audio mags and reviewer thoughts, and you will live happily ever after. If you can keep dissatisfaction out of the mix, you will be the big winner in these sweepstakes.
