BDP-1 - Switching between MPD and Roon Ready
0 Members and 1 Guest are viewing this topic. Read 2149 times.
Krutsch
« on: 11 Apr 2017, 01:50 pm »
Switching between MPD and Roon on the BDP has been hit-or-miss with the drop-down menu on the dashboard. Often when I switch from one to the other, the little pop-up on the lower-right tells me to "Check Services". When I do that, I see that the previous selected component is active.
Also, about 1/2 of the time, when I switch from MPD to Roon or vice-versa, the drop-down lists Shairport-Sync as the selected option (even though I didn't choose that one). This happens regardless of how careful I am with the mouse to click MPD or Roon Ready in the list of options.
This behavior is pretty consistent. I am using the current release (not a BETA):
S2.32 2017-02-13
Build: Manic Moose
MPD: 0.19.21 NEWS
Kernel: 3.16-0.bpo.2-486
Krutsch
Re: BDP-1 - Switching between MPD and Roon Ready
« Reply #1 on: 11 Apr 2017, 02:05 pm »
Another, related issue: when I restart my BDP-1, the Services section often looks like this:
...which requires me to manually de-select what I don't want running.
Krutsch
« Reply #2 on: 13 Apr 2017, 03:29 pm »
With the latest BETA, this seems to be fixed. Nice work.
BETA
S2.33 2017-04-07
Dashboard v2
Search function, artist and album results are useable
Artist results could use more work, but functional
Change filter toggle button location, upper left area of screen
Click filters title bar to close it
Filter selections should be preserved between reboots (assuming user space is using ext filesystem)
Krutsch
« Reply #3 on: 16 Apr 2017, 03:42 pm »
I was wrong... this issue is not fixed with the latest BETA. Restarting the BDP still shows the Services panel as displayed in my previous post.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 16 Apr 2017, 07:21 pm »
Hi Krutsch
I have 04/07 software and my 3 systems all show:
james
Krutsch
« Reply #5 on: 17 Apr 2017, 01:36 am »
Hi Krutsch
Thanks, James. Are you routinely switching back and forth between Roon and MPD?
« Reply #6 on: 17 Apr 2017, 01:30 pm »
That's a good point - no I typically use one or the other on each system.
james
TJ-Sully
« Reply #7 on: 25 Apr 2017, 06:42 am »
hey Krutsch, i share the same experience when switching between Roon and MPD on my BDP1 - but i have not updated to the new April 7th release. I'll do that tomorrow and see what happens! cheers.
