Flat Screen TV Solution
0 Members and 1 Guest are viewing this topic. Read 2931 times.
dpatters
« on: 8 Apr 2017, 10:33 am »
I sourced some AQD Diffuser panels from PI Audio Group.  I attached some foam to the back of the panels to protect the tv screen and modified wreath hangers that are also attached to the back for installation.  It takes a couple minutes to put them on.
Much improved imaging and sound stage.
Don P.
poseidonsvoice
    • 2 channel/7 channel setup
Re: Flat Screen TV Solution
« Reply #1 on: 8 Apr 2017, 10:41 am »
Nice  :thumb:
Best,
Anand.
dpatters
« Reply #2 on: 8 Apr 2017, 10:43 am »
Thanks Anand.  Good to hear from you.
Don
S Clark
« Reply #3 on: 8 Apr 2017, 11:08 am »
I have a pair on my TV exactly like yours, with exactly the same result.  I find them to be effective and reasonably priced.
max190
« Reply #4 on: 8 Apr 2017, 01:22 pm »
Room and system look really good.
Probably a PITA to move, but have you ever listened to your system without that coffee table?
dpatters
« Reply #5 on: 8 Apr 2017, 02:20 pm »
Max,
The coffee table is a PITA. We are going to replace it with something other than a glass top.  In the beginning of a kitchen remodel now, but the table is on the list. Can't eliminate it but I'm thinking a leather or wood top.
Thanks for the compliments!
Don
Audiophile
« Reply #6 on: 24 Jul 2017, 04:09 pm »
Very Nice!
What are the AQD Diffuser panels made of? I didn't see anything on the website.
poseidonsvoice
« Reply #7 on: 24 Jul 2017, 04:20 pm »
Very Nice!
EPS = Expanded Polystyrene. Not soft foam.
Best,
Anand.
twitch54
« Reply #8 on: 24 Jul 2017, 04:45 pm »
Much better than an 'ole blanket any day ! .......  :thumb:
Audiophile
« Reply #9 on: 24 Jul 2017, 05:00 pm »
Best,
Anand.
Thanks Anand!!
Audiophile
« Reply #10 on: 24 Jul 2017, 05:49 pm »
Lol. I'm sure of that!  8)
brj
« Reply #11 on: 24 Jul 2017, 07:14 pm »
Don, do you have a pic of the mounting mechanism on the TV?  Curious as to the details...  thanks!
« Reply #12 on: 25 Jul 2017, 10:55 am »
Max,
Don
About 12 years ago we found a leather covered coffee table that was soft like a large ottoman.  Great for putting your feet up and light enough to move to create seating for extra guests, but we needed to add a serving tray (that we can quickly pull out) for it to hold drinks.
