replacing rythmik driver with GR?
0 Members and 1 Guest are viewing this topic. Read 2387 times.
guf
« on: 8 Apr 2017, 06:33 am »
My local  craigslist has a Rythmik f12 sub with the aluminum driver, Could i replace it with GR's paper driver? will it it be plug and play? thanks!
Ern Dog
Re: replacing rythmik driver with GR?
« Reply #1 on: 8 Apr 2017, 03:48 pm »
Yes, it's very easy to do.  No soldering required.  It involves removing 2 sets of connection wires.  It will take about 10 min to do it.
« Last Edit: 9 Apr 2017, 04:21 pm by Ern Dog »
Danny Richie
« Reply #2 on: 9 Apr 2017, 02:10 am »
Yes, you can swap the drivers in an out from one another.
For audiophile applications the lighter weight paper based cone will sound better and have a more natural sound. The paper cone version is also better for playing up into higher ranges. If you are beating on it to near X-max with action movies then the aluminum cone might suit your needs better.
Ern Dog
« Reply #3 on: 10 Apr 2017, 12:09 am »
 Guf, did you score the Craigslist sub?   8)
guf
« Reply #4 on: 10 Apr 2017, 12:52 am »
I sent him an offer and he denied me! He'll call back. Then i'll message you.
