0 Members and 1 Guest are viewing this topic. Read 9999 times.
No chit Sherlock, but if you feel you can discern 500 hrs tube use in your Rogues I say ........... BS !! If you read my post you know that I also have a respectable SS amp (Plinius SA-102) so I know full well of the differences, as for the Rogues they are a piece of cake to maintain, if you had problems then either your amps were at fault or you were ......... I suspect the latter ......
Relax, dude, 500 hours was just a hypothetical number. The point was that tubes deteriorate over time, and for each tube, it's unpredictable whether they will last or not. That's a fact. And I never said I had mechanical problems with my Rogue tube monos. It's the fragile tubes themselves that will eventually present a problem for virtually any tube amp. That's why richidoo suggested having spare tubes on hand.
I have seen the schematics for that amp. It looks like a bit of a mess inside. I would have the tech change the caps before it even gets turned on, unless the caps are really high end (blackgate, etc.).
Hmm then maybe I should get out while I still can. The only thing I have found for a pricepoint is a pair that sold in Japan for 2250 earlier this year. Sound about right?
Keep in mind these are ask prices, not transacted prices.
Thanks for all the replies. I have not personally powered them on yet. Plan on warming them up slowly on a variac to make sure I don't release the magic smoke. I was posting in this circle because I was wondering if there were any mods for increased stability and reliability. I've only seen someone mention a mod that allows the usage of el509 tubes which seem more common.
......And the second option and question would be, could I cannibalize the insides to make it into a ZOTL amp, which would be far more stable and something I would be more comfortable playing.
....... but this thread has certainly cast OTL amps in a different light for me.
So Sumokitty, do you normally assume the "Chicken Little" attitude of "The sky is falling" everyday before you've even bothered to look at the sky ? To all of you who responded before you even knew whether the OP was actually having a difficulty of some manner, I have one question for you. Have you ever heard that saying about why it's basically a waste of time to "assume" anything ? He,he,he.... probably not !Ok ! Everyone can go back to trying to find the best route to take for going around a circle (It's really not a requirement to take this website's name literally;Unless of course you have nothing else to do)
