0 Members and 1 Guest are viewing this topic. Read 9995 times.
All tube amps are a pain in the ass to own and run. But if you want the tube sound, you have to tolerate the good with the bad. You have to just accept that, "it is what it is," and focus on the good.Forget about efficiency and heat and specs and cost with tubes. If it gets hot, crank up the A/C. Their only redeeming value is the sound. For tube lovers the sound is worth the many inconveniences. To be happy while owning a tube amp you must have an open minded tolerant attitude to expect trouble and be prepared to deal with it by having spare parts on hand, and the ability to do basic repairs yourself, or a local tech. If you are impatient and shallow, a tube amp can be a wonderful long term spiritual lesson. Worrying about heat, maintenance, reliability are against the tube religion. Tube amps help you worship the art of music, but they try your patience. Just think of it as a beast of burden, a hated appliance that is a necessary evil. Your music requires it so you indulge in tubes for the sake of the music you love. Use and abuse the tube amp because it deserves it, because you know in the long run no matter how badly you think of it it will always hate you more and frustrate you. Be prepared to laugh at it when it breaks, then shove in new tubes and shout "Now get back to work you obsolete piece of junk!" If you like the sound of it then just pump in the tubes it needs to deliver the pleasure. Like a hotrod needs more gas to deliver the rewards. If you get hung up on tube amp flaws then you are not made for tubes. It is what it is. Everything is bad and obsolete except the sound. Figure out how long the tubes last, evaluate the price per year and decide if it's worth it, but evaluate while listening to them playing music so you have correct perspective. You can never justify owning tube amps on paper without factoring in the intangibles like sound quality and listening pleasure. A hotrod is always a poor choice for transportation and a Honda Accord is always a poor choice for entertainment. Both are valid choices depending on your needs and desires. Tubes are for the desires!
Wrong ........... you obviously have not experienced modern tube amplification. I'm currently running a pair of Rogue M-180 mono blocks , piece of cake and no more heat than my Plinius SA-102 biased fully into Class A
Several years ago, I replaced my Rogue M-120 monoblocks for a SS amp for the reasons richidoo mentioned. OK, his statements were a bit over the top, but nonetheless true, in general. Tubes degenerate over time, so even if the stated tube life is 50,000 hours, the sound quality may slowly begin to diminish starting at 500 hours, and you won't notice it until you pop in a fresh new pair of the exact same tubes.
My only suggestion is NEVER leave the amplifier on without YOU being present.
I bought a pair of Counterpoint SA-4 OTL amps and have dug around more. Now I am worried about heat generation and going through tubes like candy. Do all OTL speakers suffer from the same problems or are the counterpoints a more stable design? And are there any mods that make it more reliable?
Okay, your post and questions seem reasonable, but some of the responses seem quite a bit off topic. Traditional OTL amplifiers can be problematic, and chew up tubes because of their architecture. However, ZOTL OTL amps from David Berning Co. are different. They are super reliable, easy on tube life (sometimes 100,000 hrs.+), and safe. It's a completely different way of doing OTL, and they sound terrific. You can learn more about them here:http://www.davidberning.com/and here:http://www.lineartubeaudio.com/the-technology
There ZOTLs are great sound amps, seems they arent sell direct from the Berning site, but by a dealer net, what means hi prices;
