0 Members and 1 Guest are viewing this topic. Read 2239 times.
1) How much do you listen to streaming vs owned content?2) Do you use or have any interest in voice control for equipment control?3) Do you have any interest in AI driven music selection or curation?
2. Never thought about it, but probably would if it worked properly.
2. I imagine it will eventually be so cheap that every component will have this feature.
2.) Maybe, if it works much better than Siri does now.
2 - 0% interest in voice commands.
The machine was rather difficult to operate. For years radios had been operated by means of pressing buttons and turning dials; then as the technology became more sophisticated the controls were made touch-sensitive--you merely had to brush the panels with your fingers; now all you had to do was wave your hand in the general direction of the components and hope. It saved a lot of muscular expenditure, of course, but meant that you had to sit infuriatingly still if you wanted to keep listening to the same program.
I am not a gadget or cutting edge guy at all, but I kinda stumbled into the Amazon Echo Dot and think it's really cool, and I have become a bit of a homer.The Echo Dot is $50. It works pretty much flawlessly, and understands what I say darn near almost all the time. I just speak and it hears and does, no need to face it or yell at it or any of that stuff. I believe the Google product is similar. I don't use Siri for anything so I don't know how that compares.I had no interest either until I used it. "Shuffle Frank Sinatra" is a whole lot easier than...well, a whole lot easier than pretty much anything except thinking about Frank Sinatra.
