Super V
0 Members and 1 Guest are viewing this topic. Read 1150 times.
cleestedwood
Super V
« on: 28 Mar 2017, 03:55 am »
Looking at a Jolida FX-10  10 watt tube amp to drive the Super Vs. Any advice or opinions if that is the way to go ?
« Last Edit: 28 Mar 2017, 06:03 am by cleestedwood »
danvprod
Re: Super V
« Reply #1 on: 28 Mar 2017, 10:57 am »
I run my Super Vs to a sufficient level in my 14' x 16' room using a Decware MiniTorii (4WPC). I don't have any experience with the amp you've listed here, but in terms of efficiency, I've found no problem in driving the Vs with a flea-powered amp.
Shakeydeal
Re: Super V
« Reply #2 on: 28 Mar 2017, 01:29 pm »
I am driving Super Vs in a fairly large room (15 x 26) with a 22 watt SET. I tend to listen at high levels from time to time, so not sure 10 watts would do it for me. That said, I never want for volume with my Line Magnetic integrated.
If you listen at sane levels, I'm sure 10 watts is plenty.
Shakey
