0 Members and 1 Guest are viewing this topic. Read 3718 times.
Drooling here.... Still about 3 weeks away or so from my HO Alnico monitors...
My Omega SAHO's sound best toed in, pointing just a smidgen outside my left and right ears. Creates a very vivid 3D soundstage. You'll need about 200 hours for full break in, bass can sound a little muddled until then. Happy listening.NB
I don't know if this has been answered elsewhere, so I'll give it a go here. The specs say 4-6ohms, but what are they really? Heh. The reason I ask is because I have a buddy who just bought some speakers rated at 8ohms; he measured them, and lo and behold they were 4ohms. So, does anybody measured these to see what they are?
How did your buddy measure the speakers? If he put a multimeter across the terminals with them unconnected they may read 4 ohms resistance, but impedance comprises resistance, capacitive reactance, and inductive reactance. It is likely that the the actual impedance is higher than 4 ohms, but to measure it you will need a frequency generator, load resistor and multimeter. Even then they impedance will be nominal; it will vary over the frequency range of the speaker. The nominal impedance of the speaker will be about 25% greater than the minimum. If your buddy's speaker measured 4 ohms resistance, it likely would have a minimum impedance of about 4.6 ohms, and is probably a realistic 6 ohm nominal speaker. Steve Deckert is of the opinion that most 8 ohm speakers are really 6 ohms speakers and designs his amps to that specification.
All the frequencies. That is why a sweep generator is typically used. You don't know the impedance unless you know if over its entire frequency range.http://www.wikihow.com/Measure-Speaker-Impedance
